Topic: Fireface UC input signal blinking without anything plugged in
Hi
I have a static mic plugged in input 1, with 48v engaged. The signal LED for this input flashes as it should on audio signal input, but the signal LED for input 3 - which has nothing plugged in - also flashes in perfect sync with input 1 IF (and only if) input 3 is set to "instrument". An audio signal input is also detected in TotalMix.
Audio is actually recorded in a track routed to input3 in this configuration, and sounds like a very bit reduced version of the source audio.
I reckon this is a bug?
Thank you
Guillaume
