Topic: MIDI in CC and standalone mode
I wonder if it is possible to control my UCX via MIDI while not in USB mode with my iPad. here is what I tried:
first check with USB connection: Sending Midi Ctl messages or the equivalent Mickie pb message from MaxMSP via external Midi interface to Midi in 1 of the UCX works fine in USB mode to control input Fader. for the fader message I first sent a message to select the right subgroup in the 3rd row, then the right msg to change the fader value. Changing setups via note message works also fine. Midi in standalone is checked.
with the same midi connection and message setup I switched to standalone (cc off)disconnecting USB. I found changing setup via note msg still works but changing the Fadervalue did not work any more.
changing to CC mode and connecting the iPad none of my Midimessages seemed to work any more.
is this correct, or did I miss anything?
my goal is to control the faders and setup via MIDi or OSC switching while in CC mode running totalmix for iPad.
thanks Falk
ps:
here is a Maxpatch to send Midi messages it runs with Max Demo. Paste the text in an empty Max doc in edit mode...
<pre><code>
----------begin_max5_patcher----------
865.3ocyX0taaBCE82IOEVn8yrJaCXB6cXOASSU7gaq6.6Hvzkpp9tO+AzQ6
BFWBqM+gHbt3iOGetWegm1tIHWbj1F.9F3GfMadZ6lMlgzCro+9MA0YGKpxZ
MgEvo+VjeevN6eIoGklgk.FHeXzCYxh6X7autgVHsSNI5J3NP5d80Pn9JFeE
D7y9mPzIqnR4iGn1vCXbYvNPPdF+1fWhhUZvRg+WSSF.i2Uy3pG1r7P8C1Je
rxLUAiByBhINrdvm2tUeYmmLuPTWS0Kq2PcAu5QPKkWBZ6xqYGAE2oV0TffW
PGBthwoEhNt4IvSKSXXnUav5ePXycggiTpwZPnSM3PCUspjYRlfOFhPyVAJN
Q+Cr+xKy+bJGbEUtdg5grJf3FvMrlVI3lrRZiKiDxHIFiDJL1nVvIzG7RzmX
qGM8SWcpossYJ4oWkjhA+E585pPQl8ZbZnOtJzYkYslJPaAkSAXGtgHTxn7k
3PW1g8oKwNLf.5yOcwJGHGxQXDwe4X+Ey9bonKuRYzqXE+x3yoUJJA9NqjoP
b1SUBSLrFkfcxWxR19I3QH7ot6uXQJzVrzSUJ9C2UzWm6eHbLzAoP6smPRr8
RjdU7bcTbx1HRNcMArmzEs.5NQCTkzJOnaJxW5NYmSIIWJTVvo5UoyJZHb5n
JZjj46bzPbWsNlPNKAXIsNplgb2c0XJjYuF6Q6wtIHzcktrlrZpj1bMkmka4
Jb2KqZVcWsIbbxvfL9vfvY5sDZ8m1Sdd2kKwqX0iuf.HH1o2xZs5KgD6g05j
pM4iuDxTbVS4HUWwdjOQhOORStXHcbL.5baNBYOwK13MihVHkw6cR4oxHP12
WAGsnLhUUnhlQnB6OL8bEpKlCX3BIcldircC022rk3uhxi3E5zd9v+isFMAu
JjUtoEBEMhVQPWzJc0XkY1MuT5a9hRlUnd7WS0VQWSwfUZ3fKveWjkzVIiax
nFEj9K+nC5jxouHMLINQRWYecPBMCR5VRFsbDM5uAxj4BqKzomFZ3YAM1G8E
QVA8UWV9iAo2nTSHmqg6LwG0y3YPmKRDexCVC0i3i5sFIbDxh.xV7J6vgGnM
s8AavPUQ9dgIkvzOrtaX6slRjAMzGXCwGaFIqQUNVppE20XqbdjDEXeTgJ4h
2w5SsUH+71+.XWqVS.
-----------end_max5_patcher-----------
</code></pre>
