Topic: TotalMix 1.53 b1 on iMac 27" 2017with MacOS Mojave 10.14 does not work
what can i Do? i am using new iMac 27" 5k Retina 2017 (MacOS Mojave 10.14) and connected it my Fireface UCX and this Programm (TotalMix 1.53 b1) does Open, but i Cant load a Device on (File -> New TotalMix Window) - there is no Device selectable.  I also run a latest Flash update with macBook 2013 with MacOS 10.12
Who can help?
Greeintgs
15" MacBook Pro 2019 / 2,6 GHz i7 / 16 GB
iMac 27" 2017 / 4,2 GHz i7 / 32 GB
Logic x  & Fireface UCX
2 (edited by JRT 2018-11-19 13:23:30)
Re: TotalMix 1.53 b1 on iMac 27" 2017with MacOS Mojave 10.14 does not work
Apple tech-note related to third party drivers:
https://developer.apple.com/library/arc … index.html
RME tech-note related to the above:
https://www.rme-audio.de/download/AG_RM … ion_EN.pdf
Related RME download page:
http://www.rme-audio.de/en/downloads/driver/uc.php
Driver for UCX on USB on Mac OS Sierra 10.12 and up (current as of date and time of this post):
https://archiv.rme-audio.de/download/dr … ac_310.zip
Flash update tool for UCX on Mac (current as of date and time of this post):
https://archiv.rme-audio.de/download/fut_usb_mac.zip
Hello JRT, thanks for the Reply. On my Mac, the problem solved itself, also had other construction sites. I had to reset my PRM and now it works again.
But then I had the same problem on my MacBook with a different operating system
MacBook Pro (15-inch, 2019)
MacOS 10.14.6
finally it works also on my MacBook.
Here are a few remarks that might be useful for other people.
I Almost understood it. But I did not understood what I need to do to solve this Problem.
I know this security problem and appeared only after updating the driver 310. was asked for authorization and got the following note, with DeepL übersetzt:
"System Expansion Notice
At least one of your approved system enhancements is not compatible with future macOS versions. Contact "RME GmbH" for support."
Original German Alert:
"Systemerweiterungshinweis
Mindestens eine von dir genehmigte Systemerweiterungen sind mit zukünftigen macOS-Versionen nicht mehr kompatibel. Wende dich für Unterstützung an „RME GmbH“."
But now it works!
does not work
I installed it, rebooted, checked the Security Issue and it worked finally.
have the latest firmware installed
Did you notice that you replied to a one year old post? Current driver is 3.18_3...etc...
I hadn't actually noticed. I didn't recognize the forest for the trees. But the subject still seemed to be relevant.
