Thanks for confirming that none of your stuff was about Crosstalk. I would also like to note that 'was not measured like the next one' refers to your own measurements with RMAA.
Also none of the measurements that I had seen from you was about 'Jitter' as one usually thinks about it. Instead you heavily confused everyone here with two 'jitter SRC' threads (still available for anyone to read and comment on).
The first FS were sent out in the old Pro package because we still had them lying around. As long as the front panel says FS it is FS. We are not paranoid about waste and environment, but throwing hundreds of these boxes away because of just two missing letters really makes no sense.
In the end we are all glad that you now have a good working unit that makes you happy. Hopefully not only when measuring but also when listening to music.
