Topic: Please explain the clock modes with SRC
When using the internal clock, every SRC also works as a jitter killer. However, the ADI-2 Pro is
equipped with SteadyClock FS, thus operating as perfect jitter killer with any clock source. However again, a jittery input signal might degrade the quality of the sample rate conversion. The
ADI-2 Pro therefore has a second SteadyClock exclusively for the current SRC input signal to
make the sample rate conversion process as reliable and transparent as possible.
(end of quote)
when i feed spdif input with SRC (same 44.1), i can choose clock between SPDIF or INT
so what is really changing on the DAC side?
1. spdif in 44.1 -> SRC 44.1 - > clock SPDIF
2. spdif in 44.1 -> SRC 44.1 - > clock INT
