Topic: [Solved] MacOS audio crackling
suddenly, I started experiencing audio hiccups and crackles with audio in Google Chrome, using HDSPe AIO (latest driver and firmware), High Sierra,
only difference I notice is Google Chrome probably got updated,
I don't notice hiccups when using for ex. Vox app to play music from network storage (so I can say problem isn't network or coreaudio itself)
according to console, it's the infamous hals_overloadmessage.cpp audio io overload rme driver thing
I can see tons of various repeated messages like these:
default 18:27:00.599445 +0200 kernel - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default 18:27:00.599447 +0200 kernel +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default 18:27:00.599450 +0200 kernel + IOAudioEngine::addUserClientAction(<private>, <private>)
default 18:27:00.599451 +0200 kernel +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default 18:27:00.599452 +0200 kernel - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default 18:27:00.599453 +0200 kernel - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default 18:27:00.599463 +0200 kernel + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default 18:27:00.599464 +0200 kernel +-IOAudioEngine[<private>]::getStatusDescriptor()
default 18:27:00.599465 +0200 kernel - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default 18:27:00.601018 +0200 kernel +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default 18:27:00.601022 +0200 kernel +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default 18:27:00.601023 +0200 kernel +- IOAudioEngine[<private>]::clientClosed(<private>)
default 18:27:00.601038 +0200 kernel +- IOAudioEngineUserClient[<private>]::stop(<private>)
default 18:27:00.601148 +0200 kernel + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default 18:27:00.601149 +0200 kernel +-IOAudioEngine[<private>]::getStatusDescriptor()
default 18:27:00.601151 +0200 kernel - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default 18:27:00.603674 +0200 kernel + IOAudioEngineUserClient::externalMethod, selector=0x0, arg0 0x4, arg1 0x10817b000, arg2 0x6010 arg3 0xcc
default 18:27:00.603681 +0200 kernel scalarInputCount=0x4 structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default 18:27:00.603697 +0200 kernel + IOAudioEngineUserClient::registerBuffer64 0x4 0x10817b000 0x6010 0xcc
default 18:27:00.603700 +0200 kernel + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default 18:27:00.603704 +0200 kernel + IOAudioEngineUserClient[<private>]::registerClientBuffer64 (<private>[17], 0x10817b000, 0x6010, 0xcc)
default 18:27:00.603705 +0200 kernel did not find clientBufferSetList for ID 0xcc
default 18:27:00.603758 +0200 kernel clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default 18:27:00.603760 +0200 kernel clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default 18:27:00.603761 +0200 kernel did not find clientBufferSetList for ID 0xcc
default 18:27:00.603762 +0200 kernel creating new IOAudioClientBufferSet
default 18:27:00.603764 +0200 kernel output
default 18:27:00.603764 +0200 kernel isOnline adding client
default 18:27:00.603766 +0200 kernel + IOAudioStream[<private>]::addClient(<private>)
default 18:27:00.603769 +0200 kernel - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default 18:27:00.603771 +0200 kernel - IOAudioEngineUserClient::registerClientBuffer64() result 0x0
default 18:27:00.603772 +0200 kernel - IOAudioEngineUserClient::safeRegisterClientBuffer64 returns 0x0
default 18:27:00.603774 +0200 kernel - IOAudioEngineUserClient::registerBuffer64 0x4 0x10817b000 0x6010 0xcc returns 0x0
default 18:27:00.603776 +0200 kernel - IOAudioEngineUserClient::externalMethod returns 0x0
any idea what might go wrong? I suspect Chrome either requesting bad buffer size or sample rate from the rme driver
EDIT: I did some cleanup in third-party kexts, problem still persists, here's some more logs, I can easily replicate the issue when I open couple browser tabs and keep switching between them
default 16:54:23.238804 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.238839 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.238860 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.238878 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.238895 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.238911 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.271849 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.271903 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.271937 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.271970 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.272006 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:23.355365 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:23.373245 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.373290 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.373327 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.373370 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.373401 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.373432 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.412080 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:23.426000 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.426032 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.426052 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.426070 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.426086 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.426104 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.475643 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.475683 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.475703 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.475720 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.475737 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:23.480583 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:23.504280 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:25.480807 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.480839 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.480860 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.480877 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.480894 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.480910 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.524435 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.524484 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.524523 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.524570 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.524599 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:25.608420 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:25.624750 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.624795 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.624830 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.624864 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.624897 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.624931 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.661646 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:25.674969 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.675002 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.675022 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.675039 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.675056 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.675072 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.726411 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.726444 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.726464 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.726482 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.726499 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.731163 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:25.754765 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:25.839338 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.839370 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.839389 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.839407 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.839424 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.839440 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.872638 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.872682 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.872718 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.872751 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.872784 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:25.957175 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:25.973599 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.973631 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.973666 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.973748 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.973793 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:25.973827 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.009991 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:26.023271 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.023301 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.023320 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.023338 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.023354 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.023371 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.073196 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.073227 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.073249 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.073266 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.073283 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:26.077780 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:26.101459 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:27.674010 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.674042 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.674062 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.674080 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.674096 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.674113 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.713380 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.713426 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.713456 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.713483 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.713507 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:27.804345 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:27.820328 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.820370 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.820409 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.820445 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.820479 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.820511 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.856772 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:27.870175 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.870204 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.870225 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.870242 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.870260 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.870277 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.922795 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.922827 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.922847 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.922865 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:27.922882 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:27.927562 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:27.952009 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:28.452003 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.452035 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.452055 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.452072 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.452089 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.452105 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.488987 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.489030 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.489066 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.489098 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.489135 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:28.580874 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:28.596779 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.596823 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.596859 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.596892 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.596926 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.596959 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.633891 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:28.648465 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.648512 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.648540 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.648567 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.648595 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.648622 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.698380 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.698410 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.698430 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.698447 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.698464 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:28.703090 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:28.727125 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:34.747470 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.747503 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.747523 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.747541 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.747558 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.747575 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.783786 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.783835 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.783871 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.783904 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.783953 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.838869 +0200 kernel process coreaudiod[169] crossed memory high watermark (40 MB); EXC_RESOURCE supressed due to audio playback.
default 16:54:34.838874 +0200 kernel EXC_RESOURCE -> coreaudiod[169] exceeded mem limit: ActiveSoft 40 MB (non-fatal)
error 16:54:34.865924 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:34.881943 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.881989 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.882026 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.882060 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.882091 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.882123 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.934357 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.934390 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.934410 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.934427 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.934444 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.934461 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.972750 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:34.986239 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.986270 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.986290 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.986308 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.986332 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:34.996670 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:36.680134 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.680168 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.680188 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.680206 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.680224 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.680240 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.713632 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.713680 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.713714 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.713746 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.713779 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:36.799975 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:36.815812 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.815854 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.815889 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.815923 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.815958 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.816000 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.852595 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:36.865829 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.865861 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.865881 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.865899 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.865916 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.865932 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.914780 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.914811 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.914831 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.914848 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.914865 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:36.925527 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:38.753234 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.753267 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.753287 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.753311 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.753330 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.753347 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.788146 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.788193 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.788229 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.788263 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.788296 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error 16:54:38.868595 +0200 coreaudiod HALS_IOA1Engine.cpp:365:EndWriting: HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default 16:54:38.884697 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.884746 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.884782 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.884815 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.884847 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.884880 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.936405 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.936435 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.936455 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.936472 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.936489 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.936509 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.975942 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default 16:54:38.989382 +0200 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.989413 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.989432 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.989448 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:38.989465 +0200 coreaudiod HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke: IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default 16:54:39.999631 +0200 coreaudiod HALS_OverloadMessage.cpp:159:perform: Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
Reaper, Windows 11, M2 Studio
