1 (edited by tzzsmk 2019-05-05 10:23:39)
Topic: [Solved] MacOS audio crackling
suddenly, I started experiencing audio hiccups and crackles with audio in Google Chrome, using HDSPe AIO (latest driver and firmware), High Sierra,
only difference I notice is Google Chrome probably got updated,
I don't notice hiccups when using for ex. Vox app to play music from network storage (so I can say problem isn't network or coreaudio itself)
according to console, it's the infamous hals_overloadmessage.cpp audio io overload rme driver thing
I can see tons of various repeated messages like these:
default    18:27:00.599445 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    18:27:00.599447 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    18:27:00.599450 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    18:27:00.599451 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    18:27:00.599452 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    18:27:00.599453 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    18:27:00.599463 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    18:27:00.599464 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    18:27:00.599465 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    18:27:00.601018 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    18:27:00.601022 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    18:27:00.601023 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    18:27:00.601038 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    18:27:00.601148 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    18:27:00.601149 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    18:27:00.601151 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    18:27:00.603674 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x0,   arg0 0x4, arg1 0x10817b000, arg2 0x6010 arg3 0xcc
default    18:27:00.603681 +0200    kernel      scalarInputCount=0x4  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    18:27:00.603697 +0200    kernel    + IOAudioEngineUserClient::registerBuffer64 0x4 0x10817b000 0x6010 0xcc
default    18:27:00.603700 +0200    kernel    + IOAudioEngineUserClient::safeRegisterClientBuffer64 <private>
default    18:27:00.603704 +0200    kernel    + IOAudioEngineUserClient[<private>]::registerClientBuffer64  (<private>[17], 0x10817b000, 0x6010, 0xcc)
default    18:27:00.603705 +0200    kernel      did not find clientBufferSetList for ID 0xcc
default    18:27:00.603758 +0200    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer before offset: <private>, offset size: 16
default    18:27:00.603760 +0200    kernel      clientBuffer->mAudioClientBuffer32.sourceBuffer after offset: <private>
default    18:27:00.603761 +0200    kernel      did not find clientBufferSetList for ID 0xcc
default    18:27:00.603762 +0200    kernel      creating new IOAudioClientBufferSet
default    18:27:00.603764 +0200    kernel      output
default    18:27:00.603764 +0200    kernel      isOnline adding client
default    18:27:00.603766 +0200    kernel    + IOAudioStream[<private>]::addClient(<private>)
default    18:27:00.603769 +0200    kernel    - IOAudioStream[<private>]::addClient(<private>) returns 0x0
default    18:27:00.603771 +0200    kernel    - IOAudioEngineUserClient::registerClientBuffer64() result 0x0
default    18:27:00.603772 +0200    kernel    - IOAudioEngineUserClient::safeRegisterClientBuffer64  returns 0x0
default    18:27:00.603774 +0200    kernel    - IOAudioEngineUserClient::registerBuffer64 0x4 0x10817b000 0x6010 0xcc returns 0x0
default    18:27:00.603776 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
any idea what might go wrong? I suspect Chrome either requesting bad buffer size or sample rate from the rme driver
EDIT: I did some cleanup in third-party kexts, problem still persists, here's some more logs, I can easily replicate the issue when I open couple browser tabs and keep switching between them
default    16:54:23.238804 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.238839 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.238860 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.238878 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.238895 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.238911 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.271849 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.271903 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.271937 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.271970 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.272006 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:23.355365 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:23.373245 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.373290 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.373327 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.373370 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.373401 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.373432 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.412080 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:23.426000 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.426032 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.426052 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.426070 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.426086 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.426104 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.475643 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.475683 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.475703 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.475720 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.475737 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:23.480583 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:23.504280 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:25.480807 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.480839 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.480860 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.480877 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.480894 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.480910 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.524435 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.524484 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.524523 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.524570 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.524599 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:25.608420 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:25.624750 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.624795 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.624830 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.624864 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.624897 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.624931 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.661646 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:25.674969 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.675002 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.675022 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.675039 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.675056 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.675072 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.726411 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.726444 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.726464 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.726482 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.726499 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.731163 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:25.754765 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:25.839338 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.839370 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.839389 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.839407 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.839424 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.839440 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.872638 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.872682 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.872718 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.872751 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.872784 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:25.957175 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:25.973599 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.973631 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.973666 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.973748 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.973793 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:25.973827 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.009991 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:26.023271 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.023301 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.023320 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.023338 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.023354 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.023371 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.073196 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.073227 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.073249 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.073266 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.073283 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:26.077780 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:26.101459 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:27.674010 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.674042 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.674062 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.674080 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.674096 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.674113 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.713380 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.713426 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.713456 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.713483 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.713507 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:27.804345 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:27.820328 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.820370 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.820409 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.820445 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.820479 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.820511 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.856772 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:27.870175 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.870204 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.870225 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.870242 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.870260 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.870277 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.922795 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.922827 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.922847 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.922865 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:27.922882 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:27.927562 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:27.952009 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:28.452003 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.452035 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.452055 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.452072 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.452089 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.452105 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.488987 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.489030 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.489066 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.489098 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.489135 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:28.580874 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:28.596779 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.596823 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.596859 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.596892 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.596926 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.596959 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.633891 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:28.648465 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.648512 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.648540 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.648567 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.648595 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.648622 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.698380 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.698410 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.698430 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.698447 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.698464 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:28.703090 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:28.727125 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:34.747470 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.747503 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.747523 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.747541 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.747558 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.747575 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.783786 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.783835 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.783871 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.783904 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.783953 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.838869 +0200    kernel    process coreaudiod[169] crossed memory high watermark (40 MB); EXC_RESOURCE supressed due to audio playback.
default    16:54:34.838874 +0200    kernel    EXC_RESOURCE -> coreaudiod[169] exceeded mem limit: ActiveSoft 40 MB (non-fatal)
error    16:54:34.865924 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:34.881943 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.881989 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.882026 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.882060 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.882091 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.882123 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.934357 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.934390 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.934410 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.934427 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.934444 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.934461 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.972750 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:34.986239 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.986270 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.986290 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.986308 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.986332 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:34.996670 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:36.680134 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.680168 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.680188 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.680206 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.680224 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.680240 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.713632 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.713680 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.713714 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.713746 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.713779 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:36.799975 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:36.815812 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.815854 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.815889 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.815923 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.815958 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.816000 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.852595 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:36.865829 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.865861 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.865881 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.865899 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.865916 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.865932 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.914780 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.914811 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.914831 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.914848 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.914865 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:36.925527 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:38.753234 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.753267 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.753287 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.753311 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.753330 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.753347 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.788146 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.788193 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.788229 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.788263 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.788296 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
error    16:54:38.868595 +0200    coreaudiod    HALS_IOA1Engine.cpp:365:EndWriting:  HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
default    16:54:38.884697 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.884746 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.884782 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.884815 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.884847 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.884880 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.936405 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.936435 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.936455 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.936472 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.936489 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.936509 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: output stream[4] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.975942 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
default    16:54:38.989382 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 181: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.989413 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[0] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.989432 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[1] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.989448 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[2] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:38.989465 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 181: input stream[3] => Disabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    16:54:39.999631 +0200    coreaudiod    HALS_OverloadMessage.cpp:159:perform:  Audio IO Overload inputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' outputs: 'com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225, com_RME_driver_HDSPMADIEngine:225' cause: 'Unknown' prewarming: no recovering: no
HDSPe AIO, ADI-2 DAC, Fireface UFX, Octamic D, Octamic II
Reaper, Windows 11, M2 Studio
Re: [Solved] MacOS audio crackling
update: I noticed new types of errors today:
error    10:51:28.419278 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
error    10:51:28.419411 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
error    10:51:28.419513 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
error    10:51:28.419577 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
error    10:51:28.420080 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
error    10:51:28.420131 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
error    10:51:28.420210 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
error    10:51:28.420251 +0200    systemstats    AudioHardware.cpp:958:AudioObjectRemovePropertyListenerBlock:  AudioObjectRemovePropertyListenerBlock: no object with given ID 53
default    10:51:28.420767 +0200    callservicesd     [INFO] -[AVInternalDeviceList init]_block_invoke:500 hardwareListener: selector=0x64496e20
default    10:51:28.420768 +0200    callservicesd     [INFO] -[AVInternalDeviceList init]_block_invoke:500 hardwareListener: selector=0x64657623
default    10:51:28.422608 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422619 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422639 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422647 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422660 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422668 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422680 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422688 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422700 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422707 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422719 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422725 +0200    callservicesd     [INFO] -[AVInternalDeviceList notifyDeviceListChanged]_block_invoke_2:566  <private>
default    10:51:28.422769 +0200    callservicesd    Audio devices changed
default    10:51:28.422863 +0200    callservicesd    Choosing preferred device from list if one exists: <private>
default    10:51:28.422900 +0200    callservicesd    Audio device list changed
default    10:51:28.422918 +0200    callservicesd    Audio devices changed
default    10:51:28.423043 +0200    callservicesd    Choosing preferred device from list if one exists: <private>
default    10:51:28.423076 +0200    callservicesd    Audio device list changed
default    10:51:28.423104 +0200    callservicesd    notification: <private>
default    10:51:28.423158 +0200    callservicesd    notification: <private>
error    10:51:28.451768 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:28.651778 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:28.851778 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:29.050829 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:29.251689 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:29.451512 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:29.651794 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:29.851363 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:30.051800 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:30.251793 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:30.451545 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:30.651734 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:30.851799 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:31.051758 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:31.251781 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:31.451800 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:31.651518 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:31.851799 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:32.051541 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:32.251417 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:32.451471 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:32.651496 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:32.851690 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:33.050735 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:33.251416 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:33.451058 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:33.651782 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
default    10:51:33.833993 +0200    useractivityd    -- Demoting self.advertisingProcess to nil (was UserActivityClient(pid=2679/com.google.Chrome uuids={A163CCDE-EC5F-4147-9682-82D1925C53CC })) and trigger pickNewAdvertisement because the previous advertisingProcess had a current activity.
default    10:51:33.835325 +0200    useractivityd    DETERMINE: No item is being advertised, so removing any previously set of advertised items.
default    10:51:33.838187 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 174: pushing 1 output stream(s) to 'AppleHDAEngineOutputDP:0,1,0,1,2:0:{AC10-A0FA-30394A4C}'
default    10:51:33.838219 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 174: output stream[0] => Enabled: 'AppleHDAEngineOutputDP:0,1,0,1,2:0:{AC10-A0FA-30394A4C}'
default    10:51:33.841369 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 175: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841400 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: output stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841421 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: output stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841439 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: output stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841457 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: output stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841481 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: output stream[4] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841503 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 175: pushing 4 input stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841523 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: input stream[0] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841541 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: input stream[1] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841559 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: input stream[2] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.841577 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 175: input stream[3] => Enabled: 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:33.843860 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice': Updating 1 output stream(s)
default    10:51:33.843889 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice': Updating 1 input stream(s)
default    10:51:33.843934 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 176: pushing 1 output stream(s) to 'MMAudioDevice'
default    10:51:33.843956 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 176: output stream[0] => Enabled: 'MMAudioDevice'
default    10:51:33.843979 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 176: pushing 1 input stream(s) to 'MMAudioDevice'
default    10:51:33.843998 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 176: input stream[0] => Enabled: 'MMAudioDevice'
default    10:51:33.843997 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice': Updating 1 output stream(s)
default    10:51:33.844050 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice': Updating 1 input stream(s)
default    10:51:33.846354 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice_UISounds': Updating 1 output stream(s)
default    10:51:33.846387 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice_UISounds': Updating 1 input stream(s)
default    10:51:33.846448 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 177: pushing 1 output stream(s) to 'MMAudioDevice_UISounds'
default    10:51:33.846478 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 177: output stream[0] => Enabled: 'MMAudioDevice_UISounds'
default    10:51:33.846503 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 177: pushing 1 input stream(s) to 'MMAudioDevice_UISounds'
default    10:51:33.846516 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice_UISounds': Updating 1 output stream(s)
default    10:51:33.846524 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 177: input stream[0] => Enabled: 'MMAudioDevice_UISounds'
default    10:51:33.846574 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice_UISounds': Updating 1 input stream(s)
default    10:51:33.848597 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.rogueamoeba.InstantOn:0': Updating 0 output stream(s)
default    10:51:33.848633 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.rogueamoeba.InstantOn:0': Updating 0 input stream(s)
default    10:51:33.850970 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.staticz.audio.soundcontrol.masterOutput': Updating 1 output stream(s)
default    10:51:33.851001 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.staticz.audio.soundcontrol.masterOutput': Updating 0 input stream(s)
default    10:51:33.851026 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 179: pushing 1 output stream(s) to 'com.staticz.audio.soundcontrol.masterOutput'
default    10:51:33.851047 +0200    coreaudiod    HALS_IOContextDescription.cpp:1117:PushStreamUsageToEngines_block_invoke:  IOContext 179: output stream[0] => Enabled: 'com.staticz.audio.soundcontrol.masterOutput'
default    10:51:33.851093 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.staticz.audio.soundcontrol.masterOutput': Updating 1 output stream(s)
error    10:51:33.851615 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
default    10:51:33.855087 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:33.855094 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:33.855097 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:33.855099 +0200    kernel      ConnectionID:0x86c0f6c
default    10:51:33.855104 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:33.855105 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:33.855110 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:33.855112 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:33.855113 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:33.855114 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:33.855125 +0200    kernel    - IOAudioEngineUserClient[<private>]::registerFormatNotification(0x<private>, 0x100) returns 0x0
default    10:51:33.855127 +0200    kernel    - IOAudioEngineUserClient::registerNotificationAction(<private>, <private>) returns 0x0
default    10:51:33.855128 +0200    kernel    - IOAudioEngineUserClient[<private>]::registerNotificationPort(0x<private>, 0x0, 0x100) returns 0x0
error    10:51:34.051497 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:34.250668 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:34.450840 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:34.651509 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:34.850843 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:35.051773 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:35.250698 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:35.451780 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:35.651479 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:35.851781 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:36.051735 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:36.251527 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:36.451722 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:36.651342 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:36.851793 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
default    10:51:36.956588 +0200    nfsd    unrecognized export option: network
error    10:51:37.051697 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:37.251789 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:37.450749 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:37.650726 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:37.851537 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:38.050707 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:38.251242 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:38.450868 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:38.651720 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:38.851392 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:39.051794 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:39.250729 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:39.451728 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:39.650945 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:39.850827 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:40.051422 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:40.250835 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:40.451045 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:40.651805 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:40.851480 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:41.051760 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:41.250917 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:41.450807 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:41.650760 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:41.850992 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:42.050702 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:42.251632 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
default    10:51:42.280286 +0200    useractivityd    DETERMINE: A163CCDE-EC5F-4147-9682-82D1925C53CC/<private> as the current item-to-advertise.
error    10:51:42.450693 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:42.650853 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:42.851062 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:43.050722 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:43.251405 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:43.450989 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:43.651782 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
default    10:51:43.740482 +0200    Google Chrome    OSErr AERemoveEventHandler(AEEventClass, AEEventID, AEEventHandlerUPP, Boolean)(GURL,GURL handler=0x7fff3362f52c isSys=NO) err=0/noErr
default    10:51:43.740551 +0200    Google Chrome    OSErr AERemoveEventHandler(AEEventClass, AEEventID, AEEventHandlerUPP, Boolean)(WWW!,OURL handler=0x7fff3362f52c isSys=NO) err=0/noErr
default    10:51:43.742112 +0200    useractivityd    DETERMINE: No item is being advertised, so removing any previously set of advertised items.
default    10:51:43.802845 +0200    mediaremoted    Client <MRDMediaRemoteClient 0x7fa903519c80, bundleIdentifier = com.google.Chrome, pid = 2679> invalidated.
default    10:51:43.802924 +0200    useractivityd    Removing client <private>, application [pid=2679/2680 uid=501/501 gid=20/20 asid=100008 sb=YES], from known userActivityClients.
default    10:51:43.802903 +0200    mediaremoted    [MRDAgentServer] Clearing agent <private>
default    10:51:43.803008 +0200    mediaremoted    [MRDNowPlayingOriginClient] Removing now playing client <_MRNowPlayingClientProtobuf: 0x7fa905702290> {
    bundleIdentifier = "com.google.Chrome";
    displayName = "Google Chrome";
    processIdentifier = 2679;
    processUserIdentifier = 501;
default    10:51:43.803129 +0200    mediaremoted    Removing client <MRDMediaRemoteClient 0x7fa903519c80, bundleIdentifier = com.google.Chrome, pid = 2679>
default    10:51:43.803353 +0200    mediaremoted    [AVRoutingServer] Setting (null) to application picked routes for client <MRDMediaRemoteClient 0x7fa903519c80, bundleIdentifier = com.google.Chrome, pid = 2679>
default    10:51:43.826260 +0200    useractivityd    -- Demoting self.advertisingProcess to nil (was UserActivityClient(pid=2679/com.google.Chrome uuids={}))
default    10:51:43.835894 +0200    CommCenter    #I handleLSNotitifcation_sync: Application exited: <private>
error    10:51:43.850769 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:44.051096 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:44.250793 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:44.451587 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:44.651713 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:44.851699 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:45.051693 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:45.250839 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:45.451418 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:45.650997 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:45.850797 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
error    10:51:46.050844 +0200    TotalmixFX    AudioHardware.cpp:666:AudioObjectGetPropertyData:  AudioObjectGetPropertyData: no object with given ID 55
default    10:51:46.159734 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:46.159740 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:46.159741 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:46.159742 +0200    kernel    +- IOAudioEngineUserClient[<private>]::clientDied() returns 0x0
default    10:51:46.159751 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:46.161048 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice': Updating 1 output stream(s)
default    10:51:46.161099 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice': Updating 1 input stream(s)
default    10:51:46.161379 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice_UISounds': Updating 1 output stream(s)
default    10:51:46.161405 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'MMAudioDevice_UISounds': Updating 1 input stream(s)
default    10:51:46.161613 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.rogueamoeba.InstantOn:0': Updating 0 output stream(s)
default    10:51:46.161637 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.rogueamoeba.InstantOn:0': Updating 0 input stream(s)
default    10:51:46.161827 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.staticz.audio.soundcontrol.masterOutput': Updating 1 output stream(s)
default    10:51:46.161853 +0200    coreaudiod    HALS_IOEngine2.cpp:1075:_UpdateTotalStreamUsage:  'com.staticz.audio.soundcontrol.masterOutput': Updating 0 input stream(s)
default    10:51:46.169031 +0200    CommCenter    #I handleLSNotitifcation_sync: Application exited: <private>
default    10:51:46.957692 +0200    nfsd    unrecognized export option: network
default    10:51:52.542767 +0200    trustd    could not enable test hierarchy: no UAT pinning preferences set
default    10:51:53.795880 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.795886 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.795888 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.795936 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.795938 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.795942 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.795946 +0200    kernel      ConnectionID:0xe1d3c826
default    10:51:53.795951 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.795952 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.795957 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.795959 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.795959 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.795961 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.795975 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.795975 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.795977 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.797470 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.797474 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.797474 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.797503 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.797584 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x103A26000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.797585 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.797602 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.797602 +0200    kernel      searching for sourceBuffer 0x103a26000
default    10:51:53.797603 +0200    kernel      checking against 0x1039f1000
default    10:51:53.797604 +0200    kernel      checking against 0x1039f8000
default    10:51:53.797605 +0200    kernel      checking against 0x1039ff000
default    10:51:53.797605 +0200    kernel      checking against 0x103a06000
default    10:51:53.797606 +0200    kernel      checking against 0x103a0d000
default    10:51:53.797607 +0200    kernel      checking input
default    10:51:53.797608 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.797611 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.797611 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.797624 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.797625 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.797631 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.797632 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.797633 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.797663 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.797664 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.797667 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.797672 +0200    kernel      ConnectionID:0xe99a2177
default    10:51:53.797675 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.797676 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.797679 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.797680 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.797682 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.797683 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.797692 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.797693 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.797694 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.799034 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.799037 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.799038 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.799047 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.799141 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x103A2D000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.799144 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.799156 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.799156 +0200    kernel      searching for sourceBuffer 0x103a2d000
default    10:51:53.799157 +0200    kernel      checking against 0x1039f1000
default    10:51:53.799158 +0200    kernel      checking against 0x1039f8000
default    10:51:53.799159 +0200    kernel      checking against 0x1039ff000
default    10:51:53.799159 +0200    kernel      checking against 0x103a06000
default    10:51:53.799160 +0200    kernel      checking against 0x103a0d000
default    10:51:53.799160 +0200    kernel      checking input
default    10:51:53.799161 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.799164 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.799165 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.799175 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.799176 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.799182 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.799183 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.799184 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.799213 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.799215 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.799217 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.799219 +0200    kernel      ConnectionID:0x62963c3d
default    10:51:53.799221 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.799226 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.799229 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.799231 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.799231 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.799233 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.799242 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.799243 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.799244 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.800579 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.800583 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.800584 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.800600 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.800687 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x103A34000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.800691 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.800702 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.800703 +0200    kernel      searching for sourceBuffer 0x103a34000
default    10:51:53.800704 +0200    kernel      checking against 0x1039f1000
default    10:51:53.800704 +0200    kernel      checking against 0x1039f8000
default    10:51:53.800705 +0200    kernel      checking against 0x1039ff000
default    10:51:53.800706 +0200    kernel      checking against 0x103a06000
default    10:51:53.800706 +0200    kernel      checking against 0x103a0d000
default    10:51:53.800708 +0200    kernel      checking input
default    10:51:53.800708 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.800710 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.800711 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.800721 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.800722 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.800729 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.800730 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.800731 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.800758 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.800761 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.800763 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.800765 +0200    kernel      ConnectionID:0x9f09c088
default    10:51:53.800767 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.800768 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.800772 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.800773 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.800774 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.800775 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.800783 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.800784 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.800785 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.802111 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.802115 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.802117 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.802124 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.802194 +0200    kernel    + IOAudioEngineUserClient[<private>]::performWatchdogOutput(<private>, 4448) - (8c,468)
default    10:51:53.802206 +0200    kernel    - IOAudioEngineUserClient[<private>]::performWatchdogOutput(<private>, 4448) - (8c,568)
default    10:51:53.802218 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x103A3B000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.802220 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.802231 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.802232 +0200    kernel      searching for sourceBuffer 0x103a3b000
default    10:51:53.802232 +0200    kernel      checking against 0x1039f1000
default    10:51:53.802233 +0200    kernel      checking against 0x1039f8000
default    10:51:53.802234 +0200    kernel      checking against 0x1039ff000
default    10:51:53.802235 +0200    kernel      checking against 0x103a06000
default    10:51:53.802236 +0200    kernel      checking against 0x103a0d000
default    10:51:53.802237 +0200    kernel      checking input
default    10:51:53.802237 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.802240 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.802241 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.802253 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.802254 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.802260 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.802261 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.802262 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.802292 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.802294 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.802296 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.802303 +0200    kernel      ConnectionID:0xf5f948cc
default    10:51:53.802306 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.802307 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.802310 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.802311 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.802312 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.802313 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.802323 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.802324 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.802325 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.803656 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.803660 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.803661 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.803675 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.803773 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x1039F1000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.803777 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.803788 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.803789 +0200    kernel      searching for sourceBuffer 0x1039f1000
default    10:51:53.803790 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.803792 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.803793 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.803804 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.803805 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.803812 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.803813 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.803814 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.803844 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.803846 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.803848 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.803850 +0200    kernel      ConnectionID:0xfcbb4429
default    10:51:53.803852 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.803854 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.803857 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.803858 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.803859 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.803860 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.803869 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.803870 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.803870 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.805427 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.805432 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.805432 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.805440 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.805547 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x1039F8000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.805551 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.805564 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.805565 +0200    kernel      searching for sourceBuffer 0x1039f8000
default    10:51:53.805566 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.805568 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.805569 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.805581 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.805583 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.805590 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.805590 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.805592 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.805633 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.805637 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.805639 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.805646 +0200    kernel      ConnectionID:0x25cee329
default    10:51:53.805650 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.805652 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.805657 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.805658 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.805660 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.805662 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.805677 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.805678 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.805680 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.807119 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.807123 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.807124 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.807140 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.807236 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x1039FF000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.807241 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.807253 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.807254 +0200    kernel      searching for sourceBuffer 0x1039ff000
default    10:51:53.807254 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.807257 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.807258 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.807269 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.807269 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.807276 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.807277 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.807278 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.807297 +0200    kernel    + IOAudioEngineUserClient[<private>]::performWatchdogOutput(<private>, 4449) - (8c,568)
default    10:51:53.807306 +0200    kernel    - IOAudioEngineUserClient[<private>]::performWatchdogOutput(<private>, 4449) - (8c,668)
default    10:51:53.807317 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.807319 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.807323 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.807325 +0200    kernel      ConnectionID:0x603a2f06
default    10:51:53.807328 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.807330 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.807334 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.807336 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.807338 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.807340 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.807352 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.807353 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.807355 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.808754 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.808758 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.808759 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.808773 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.808870 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x103A06000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.808874 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.808886 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
default    10:51:53.808886 +0200    kernel      searching for sourceBuffer 0x103a06000
default    10:51:53.808888 +0200    kernel    + IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.808890 +0200    kernel    +-IOAudioStream[<private>]::safeLogError kErrorLogDumpCounters mStreamErrorCountsUpdated=0
default    10:51:53.808891 +0200    kernel    - IOAudioStream[<private>]::removeClient(<private>)
default    10:51:53.808901 +0200    kernel    - IOAudioEngineUserClient::unregisterClientBuffer64 no sourcebuffer returns 0x0
default    10:51:53.808901 +0200    kernel    - IOAudioEngineUserClient::externalMethod returns 0x0
default    10:51:53.808908 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.808909 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.808910 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.808940 +0200    kernel    + IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.808943 +0200    kernel    + IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0)
default    10:51:53.808946 +0200    kernel    +- IOAudioEngineUserClient[<private>]::setOnline(0)
default    10:51:53.808948 +0200    kernel      ConnectionID:0x87a0ce8e
default    10:51:53.808952 +0200    kernel    - IOAudioEngineUserClient[<private>]::initWithAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns 1
default    10:51:53.808953 +0200    kernel    +- IOAudioEngineUserClient::withAudioEngine(<private>, 0x<private>, <private>, 0x0, 0x0) returns <private>
default    10:51:53.808958 +0200    kernel    + IOAudioEngine::addUserClientAction(<private>, <private>)
default    10:51:53.808960 +0200    kernel    +- IOAudioEngine[<private>]::addUserClient(<private>) returns 0x0
default    10:51:53.808961 +0200    kernel    - IOAudioEngine::addUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.808962 +0200    kernel    - IOAudioEngine[<private>]::newUserClient(0x<private>, <private>, 0x0, 0x0, <private>)
default    10:51:53.808975 +0200    kernel    + IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x0, <private>)
default    10:51:53.808977 +0200    kernel    +-IOAudioEngine[<private>]::getStatusDescriptor()
default    10:51:53.808979 +0200    kernel    - IOAudioEngineUserClient[<private>]::clientMemoryForType(0x0, 0x1000, <private>) returns 0x0
default    10:51:53.810406 +0200    kernel    +- IOAudioEngine[<private>]::removeUserClient(<private>) returns 0x0
default    10:51:53.810410 +0200    kernel    +- IOAudioEngine::removeUserClientAction(<private>, <private>) returns 0x0
default    10:51:53.810410 +0200    kernel    +- IOAudioEngine[<private>]::clientClosed(<private>)
default    10:51:53.810418 +0200    kernel    +- IOAudioEngineUserClient[<private>]::stop(<private>)
default    10:51:53.810521 +0200    kernel    + IOAudioEngineUserClient::externalMethod, selector=0x1,   arg0 0x103A0D000, arg1 0x62, arg2 0x0 arg3 0x0
default    10:51:53.810526 +0200    kernel      scalarInputCount=0x2  structureInputSize 0x0, scalarOutputCount 0x0, structureOutputSize 0x0
default    10:51:53.810590 +0200    coreaudiod    HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke:  IOContext 98: pushing 5 output stream(s) to 'com_RME_driver_HDSPMADIEngine:23632225'
default    10:51:53.810537 +0200    kernel    + IOAudioEngineUserClient[<private>]::unregisterClientBuffer64(0x<private>, 0x62)
looks like HDSPe AIO dropped completely from system for a while ?
3 (edited by ramses 2019-05-05 10:11:52)
It's a hackingtosh. I wouldn't exclude that High Sierra drivers do not support the HW to 100%.
4 (edited by tzzsmk 2019-05-05 10:24:23)
SOLVED!
problem was caused by third-party application called Sound Control by Staticz,
after proper removal (which removes its kext and launch agent) via its menu and reboot, no crackles anymore
