swedishstudio wrote:Btw: I have been looking at RME Fireface UC as an alternative but I am wondering whether I am sacrificing AD/DA quality due to its much lower price-tag when you look at what you get and considering I will connect a Schoeps CMIT5U to it. An external 48V+preamp I have been looking at is Avalon V5 Silver.
Although the UC has older AD/DA converters does not mean that they are really worse.
If you pick the ADI-2 Pro then you get reference grade AD/DA converter where RME gets most out of those converter chips whats possible. And the better quality of D/A converters is audible, which means you can hear it.
The sound and stereo image and depth is better and this you can also hear on not so expensive monitors.
A friend from Vienna to whom I recommended the ADI-2 Pro was excited that even his old Yamaha monitors sound better.
I personally made the same experience with my Geithain RL 906 monitors.
They "stage" / presentation of a room is with the ADI-2 Pro FS better compared to the D/A converters in the Monitor itself and even compared to UFX+.
You can also alternatively get an UFX II which has phantastic mic preamps, the analog section has been enhanced much compared to the old flagship interface UFX. Then you have a very good compromise of very good sound, DURec, TotalMix FX and a lot of channels for other purposes.
Or you want the best AD/DA conversion, then get ADI-2 Pro FS.
And I would recommend to get TM FX on top to be able in the future to create near zero latency mixes for phones.
For this I made already a proposal to you including the integration of the very useful ARC USB.
The ultimate solution is a flagship interface (UFXII / UFX+) which supports DURec in combination with ADI-2 Pro FS.
These interfaces have
- dampening of power-on/off on all analog outputs
- DURec (direct USB recording to disk)
- you can operate the interface fully standalone and attach the ARC USB directly to the unit
- you can even attach a footswitch to the ARC USB to start/stop recording and such things
Valid Combinations for you are i.e.:
- ADI-2 Pro FS alone, but without TotalMix FX, no possibility to use ARC USB
- RayDAT + ADI-2 Pro FS, optional ARC USB (PCIe)
- UC + ADI-2 Pro FS, optional ARC USB (USB2, 9.5")
- UCX + ADI-2 Pro FS, optional ARC USB (USB2, 9.5")
- UFX II + ADI-2 Pro FS, optional ARC USB (USB2, 19", latest converter tech, new analog section)
A comparison of nearly all RME recording interfaces you can find here in an Excel attached to an blog article of mine, there you can compare converter speed, phones outputs, etc etc, lots of useful information)
Excel: https://www.tonstudio-forum.de/index.ph … 8-08-xlsx/
PDF: https://www.tonstudio-forum.de/index.ph … 18-08-pdf/
https://www.tonstudio-forum.de/blog/ind … B-MADIfac/
PS: I updated the Blog article for you now, to have up to date information, which interfaces you could combina with the ADI-2 Pro FS to be able to have TM FX routing in the setup and to use the ARC USB.
https://www.tonstudio-forum.de/blog/ind … ort-DE-EN/
