Topic: HDSPe AES Issue with Dell Precision 3630
Hi guys, I've been having issue with the HDSPe AES card with the Dell Precision 3630(spec as below), it constantly crack while playing, meanwhile had plug in a cheap Focusrite 2i2 and it works perfectly. There are 10 rooms being setup up and it all having the same problem.
Precision 3630 Tower
Intel Xeon E-2124G, 4 Core, 8MB Cache, 3.3GHz, 4.3Ghz Turbo
16GB (2x8GB) 2666MHz DDR4 UDIMM Non-ECC
2 x 3.5" 1TB 7200rpm SATA Hard Disk Drive
8x DVD+/-RW 9.5mm Optical Disk Drive
Integrated NIC included
Dell Wired Mouse MS116 Black
Dell Wired Keyboard KB216 Black (English)
Waves Maxx Audio
RAID 1 Configuration
Windows 10 Pro for Workstations (up to 4 Cores) English
Windows 10 Pro,WKSTA OS Recovery 64bit - DVD (RS3 1017)
The output goes to Studer Glacie. Hope to hear from you a.s.a.p as we are in the midst of a broadcast installation work.
