Topic: Octamix XTC connection to PC
Hi All
We have a UFXII connected via USB to Win10 PC running Totalmix, with Octamic XTC connected to UFXII using midi in/out and ADAT in and ADAT out. Solid ADAT green led shows on status display of both UFX and Octamic devices. UFXII is master (internal) and Octamic is slave served via ADAT.
When I used to look at settings in TMFX, I would see Octamic XTC as a device on a tab next to UFXII tab. That seems to have gone now, i.e. I only see the UFXII device settings. Then I realized I had removed a USB cable from Octamic to PC. This cable had been used to update Octamic firmware a couple of weeks ago, but then I removed it cos I thought only necessary for updates?
So here is my question: with the above setup should I always have Octamic XTC connected via USB cable to my PC?
Thanks for your input!
cheers
plank
