1 (edited by jotfisch 2020-01-06 15:07:07)
Topic: combining DigifaceDante with Fireface
if I use both DigifaceDante and Fireface 802 on an apple macbook by using a created Aggregate Device,
is it possible to rout signals to the outputs of both devices?
Is it possible within the Totalmix software to rout a signal from Fireface analog input directly to a DigifaceDante output???
Does anyone know?
best
jens
Re: combining DigifaceDante with Fireface
Only in the DAW software. TotalMix runs independently on each unit.
Not with these two units. You would need to make a physical connection from FF802 out to Digiface Dante input. If you had a Fireface UFX+ instead of the Fireface 802, you could make this connection with a MADI coax cable.
Thank you Jeff!
thats not the answer I was hoping for ;-)
but very helpful.
best
jens
