Some additional questions to the device:
1. is MIDI over MADI still supported by this device ?
2. Does it forward MIDI over MADI bits to devices behind on the MADI bus ?
So that it can be ..
3. .. integrated into TM FX as AUX device like the Octamic XTC to be able to save the most important settings in snapshots
4. .. remote controlled by the "MIDI Remote" application ?
5. If connected via MADI, does the 12Mic also perform Auto CA Latency compensation so that it can be mixed on the MADI bus well with i.e. Octamic XTC ?
6. Only curious, whether the ADAT outputs also support optical SPDIF protocol (for rare use cases to connect devices, which are not capable of ADAT).
Many thanks.
