Topic: HDSPe Multiface 2: Disconnect Mode only works when PC powered on.
Hi there!
I searched this forum for a post with a similar problem, but didnt find anything.
Here is my problem:
My Multiface works in disconnect mode, as long as the PC is powered on.
DSP Settings says "Disconnected" and TotalMix sliders dont change volume level. When I then disable the "Disconnect" checkbox, the sliders work again. At both times audio is routed, and everything is as expected.
But when I'm in "Disconnect" mode and I shut down my PC - as soon as the PC power supply turns off, the Multiface host LED starts blinking and audio is not routed anymore.
I did some tests:
- As soon as there is power from the PC, the Multiface works. So even when I enter the BIOS, it works (I was looking if there was a way to keep power on the PCIe bus..)
- The Multiface doesnt work when I disconnect the power supply (nothing blinks, no signal)
- The Multiface doesnt work when I disconnect the Firewire cable (HOST blinks)
Hardware: Multiface 2 with Firmware 20 and Driver 4.29 using a PCIe HDSPe Card. Power Supply is 12VDC, 2A.
I am using Windows 10, if that matters..
Has anyone got any idea what is going on?
Thanks!
Edit: Ich war mir nicht sicher in welcher Sprache ich schreiben soll. Wir können auch gerne deutsch schreiben..
