Topic: Sync Raydat with HDSP 9652
I have a Raydat (PCIe) and a HDSP9652 (PCI) card.
I always used both cards in 2 different pc, now i would like to use the in one pc!
In order to sync everything, i used to sync the HDSP9652 Word clock with the WCM attached to the Raydat.
Unfortunately i dont have any more slots available on my pc to bring the WCM out of the pc box, which i would connect anyway over BNC cable to the HDSP9652
So would'nt it be easier to sync both cards internally and avoid unnecessary cables!!!
According to the manuals on the Raydat the onboard connector X400 is labeled as Sync IN
On the other hand the HDSP9652 has a build in Word clock in and out to sync with to external equipment and the onboard connector ST7 is used to synchronize AEB4-I cards (sync out ?).
So my question connecting the ST7 connector from HDSP9652 to my Raydat Sync in (x400) and setting the HDSP9652 as master will make it work and give me access to 56 mono in and 56 mono output channels.
That would be wonderfull.
Best regards
