> When I awake the iPad it says connected, but after 5 secs this changes to offline.
What "says connected" ? Do you mean the iPADs WLAN connectivity ?
Or do you mean the TotalMix FX remote application ?
If you changed the DSL router it could be the case, that you get another DHCP pool and also other IPs.
Maybe the IP adress and port number of TotalMix on the Desktop PC does not fit anymore with the
IP address and port number, that you initially configured in the TotalMix Remote application on your iPAD.
First we need to ensure/check
- whether there is communication between the devices and
- that IP addresses do not change just in case you are using DHCP services which is much likely
For that I need to ask you a couple of question in regards to your network:
1. Whats the IP address, Netmask, default GW of Desktop PC, iPAD and new router ?
2. Are both, PC and iPAD, using Wireless LAN (WLAN) ? Or only the iPAD ?
If both devices use WLAN, then you need to check whether WLAN devices are allowed to "see" /
"communicate with" each other.
This you can e.g. check by trying a ping the IP address of the iPAD from the Desktop PC.
Alternatively check this on the DSL router itself.
My Fritzbox has such an option under WLAN -> Security
[x] Die unten angezeigten aktiven WLAN-Geräte dürfen untereinander kommunizieren
translated: The active WLAN devices shown below may communicate with each other
For other devices you might find this under a different place and using a different wording....
3. Which devices use DHCP or which use static configuration of IP address, netmask, default GW, DNS server ?
Can you successfully ping from Desktop PC to iPAD ?
From theory .. how it should work .. what you need to perform on the application:
a) Desktop PC - where the recording device is connected to
If you enable Network Remote settings in TM FX, then it takes the IP address of the network adapter
and - if you need - you can change the port number for this application, default: 7009
On this side you can not do much wrong.
You only need to ensure, that this PC always gets this IP address, either by static configuration
or by configuring DHCP services in your DSL router, to give the DHCP clients always the same IP.
This is usually not enabled by default, check this in the DHCP services of your DSL router.
b) On the TotalMix Remote client / iPAD:
Ensure that this device is in the same LAN as your Desktop PC (or you need to set a proper default GW entry).
Ensure that from iPAD you can ping the Desktop PC's IP address.
If iPAD has no ping utility or if you do not find: then try it vice versa to ping the IP of iPAD from the PC.
If ping does not work, then this indicates already a problem.
Otherwise ... if the devices are in the same LAN and can ping each other, then there should be no issue.
On iPAD in TotalMix FX Remote you only need to enter the proper IP address and port number of the Desktop PC.
