Topic: Plans for UCX update or a new USB C interface
Hiya,
Just curious if RME have any plans to release a USB C version of the UCX or some kind of equivalent.
If no - how come? Is it not possible or something else.
Thanks,
Aron
RME User Forum → FireWire & USB series → Plans for UCX update or a new USB C interface
Hiya,
Thanks,
Aron
You can use a cheap USB-C to USB-B cable...
The USB C connector thing on devices has fooled some reviewers into thinking the device itself is super speedy on the bus. This pertains to the CLARETT range that has USB C connector.
USB C spec is V E R Y fast (well, it can be). But just having the USB C physical connector itself on a device does not mean it is SUPER SPEEDY just that it has the C connector but is still likely at the original USB 2.0 speeds. I was originally looking at upgrading and assumed anything with the C connector meant latest and greatest USB spec 3.1 or whateverr, but nope, they still all operate at 2.0
I say all of this because I just built a new rig using the MSI CARBON PRO board which has a USB C port right on board and I thought about getting a USB C interface but then realized that none of them are actuallyt aht fast, nor to they really need to be.
Exactly! When I was looking for a new interface last year to go with my new 2019 MacBook Pro”, I wanted to get something that could take full advantage of the USB C connection. I was a bit surprised at the number of devices which now have USB C but only run at USB 2 speeds.
