Hi Nate,
let me guess, takes some time to fully digest it But relax, you are on a good way :-)
> How is it that Cubase is not using the PHYSICAL OUTPUTS of 5/6 and knows to use the SOFTWARE PLAYBACK channels?
The DAW thinks it sends to the physical output ..
But the TM FX software design adds this layer in between ("SW playback channels") that empower you
to have more control about the final routing.
Normally you would think, audio will be send out through HW output AN 5/6 ...
EDIT: This BTW would be the case in the "DAW mode" (this is a stripped down operational mode which deactivates all these TM FX routing features).
But with TM FX you have now this very nice freedom to be able to send this audio to whatever output(s) you want on your recording interface.
And this makes sense .. each HW output is a submix of its own.
So for Monitor A, Monitor B, Phones 1 ..4 (remember e.g. all the assignments in the control room) you can pick now from
SW playback channels what you want to make the perfect submix for each of your band members phones.
The one wants perhaps the guitars louder, the other drums or bass ...
All is possible by that.
Or keep it simple and simply route SW Playback AN 5/6 to HW Output AN 5/6 ...
