Topic: Micstasy and Octamic air circulation
We typically run two Micstasies in a 4u plastic case, and an Octamic XTC + Fireface UFX in a 2u case. Both get fairly warm after several hours of use - does RME recommend allowing additional space around these units or is the heat produced by compact placement within working tolerances?
Also, is there any kind of test to check the remaining lifespan of power supplies in RME units?
Thanks in advance
www.eastwoodrecords.co.uk
