Topic: What does USB Diagnosis mean?
In my MADIface Series Settings USB Diagnosis it shows for example 8|9|0.
I think normal would be 0|0|0
What does these numbers stand for, what do they mean?
Thanks, TvS
Re: What does USB Diagnosis mean?
It means that your USB 3 is faulty and causes drop outs. Try a different USB 3 port and other/shorter USB cables. Also maximize the ASIO buffer size in the Settings dialog and avoid sample rates higher than 48 kHz.
3 (edited by TvS 2020-07-06 09:18:06)
Thanks,
Are there any 3m usb cables you could recommend? I tried some and had the feeling one works better than the other, but non without any dropouts...
Regards TvS
