1 (edited by jthk 2020-07-12 18:11:05)
Topic: ADI-2 DAC WASAPI, 16/24 bit, and Windows Spatial Sound API
The WASAPI driver only lets the user select 32 bit depth options. This is problematic because the Windows 10 spatial sound API requires 16 or 24 bit depth. Consequently, Dolby Atmos for Headphones and DTS Headphone: X cannot be turned on because they are incompatible with 32 bit depth. While the ASIO driver seemingly fixes this problem, ASIO comes with other trade offs, like incompatible bit depth switching in Tidal.
Are there any plans to support 16 or 24 bit depth with WASAPI in Windows sound settings?
In addition, I saw one post where a user asked a somewhat similar question regarding WASAPI bit depth being pinned at 32 bit, and the answer directed the user to consult the manual. Therefore, before making this post, I consulted the manual looking for solutions or an explanation. Nothing in the manual explains why WASAPI only permits 32 bit selection in Windows. Specifically, I looked at pages 40-43 and 65.
Thanks,
John
Edit: Changed "spacial" to "spatial"
Re: ADI-2 DAC WASAPI, 16/24 bit, and Windows Spatial Sound API
Why are you bothering with WASAPI and Windows sound APIs? As soon as you use those, you've let WDM process the audio and there's no longer a reason to use WASAPI or ASIO.
3 (edited by jthk 2020-07-12 18:10:41)
Yeah, I'm probably not being precise with my language, and I certainly don't grasp a lot of the terminology. I probably don't mean WASAPI but the Windows UAC 2 driver? I was going off this: https://docs.microsoft.com/en-us/window … io-drivers which make it seem like WASAPI is always used when using the class compliant driver.
Regardless, if you're asking why I'm "bothering with" programs that use Windows spatial sound API, I'm a bit miffed by your question. Dolby Atmos for Headphones works quite well in certain games, and I'd like to use it in conjunction with my ADI-2. Unfortunately, I can't because I can only select 32 bit depth, not 16 or 24.
I just want to know if it's possible to select something other than 32 bit depth in Windows using the default Windows driver, and if it is not, I'd like to request that it be made possible so we can take advantage of programs that use the Windows spatial sound API.
EDIT: Also, I can't tell if you know what I'm talking about, here is a link: https://docs.microsoft.com/en-us/window … tial-sound
The bit depth in UAC2 mode is hard coded into the hardware (FPGA). Extending it to 24 bit is quite cumbersome and needs a lot of development work (I know it sounds easy but it is not).
Then it would be incompatible for many applications.
> I just want to know if it's possible to select something other than 32 bit depth in Windows using the default Windows driver, and if it is not, I'd like to request that it be made possible so we can take advantage of programs that use the Windows spacial sound API.
There is no documentation that says 24 or 16 bit is required as format. Windows Sonic for Headphone not available will most probably have a different reason that we will try to find out.
Thank you very much for the response, Mr. Carstens! While I'm fairly certain the spatial API requires 16 or 24 bit @ 48000, I'll be very happy if you all can figure out the what's preventing the ADI-2 DAC from working with it. Again, many thanks.
6 (edited by RPGWiZaRD 2021-07-20 13:35:42)
I'm sorry for bumping such an old thread but I also have the exact same question and the thread starter explained the case so well so thought it would be unnecessary to open a new one regarding the same topic. Basically my purchase decision relies pretty much on this as I'm looking for a "do-it-all" solution to my computer audio needs. I'm a hobby music mastering engineer/headphone enthusiast that also uses the PC to game with so I'd like to find a device which can do it all, especially when talking about devices costing about 1000€ which is a lot expensier DAC than I would be used to.
For PC gaming I tend to use 5.1 speaker setting on a soundcard that support it as I find that to deliver better positional cues than setting windows to plain "stereo" (it somehow downmixes into a stereo output but treats it as a 5.1 signal but this is not the point here so let's leave it at that). However that option is unfortunately only available to soundcards usually assumed with gaming and as we all know those typically leaves a bit more for desire when it comes to pure audio deliverance. So the next best thing I was testing all kinds of various "surround sound" APIs to see if there's any good ones available that A) doesn't impact the sound quality too much and B) has a natural sounding surround processing and to me Dolby Atmos for Headphones were the best from this aspect, quite positively suprised with the latest version that allows you to for example adjust EQ (or like I wanted, keep it totally unEQ'd which wasn't the case previously when you were forced to pre-applied EQ settings).
Dolby Atmos for Heaphones USES 24bit 48.000Hz and it MUST be set to this specifically (like it automatically switches to when enabling Dolby Atmos for Headphones), changing either sample-rate or bitrate will automatically force Windows' "Spatial sound"-setting fall back to "off", essentially turning it off. So the question is it today possible to have ADI-2 FS DAC use 24bit 48.000Hz with any Windows driver? I don't care if it's WASAPI, ASIO or even using Windows own "Direct Sound" protocol as long as it's possible. Has there been any development in this regard? Thanks
On a similar bent, I'm trying to get Dolby Atmos for Headphones to work with the RME ADI-2 DAC FS.
I can right click on the sound icon to select a surround sound mode, but cannot figure out how to get this signal to go through the ADI-2. Am I missing something, or is this impossible?
https://i.imgur.com/bI3g59G.png
8
Did you read the first post?
9 (edited by Sproketz 2023-01-21 09:09:39)
Yes. It's unclear to me if my question is the same as the one above. I'm using Dolby Atmos for Headphones rather than Window Sonic. I don't understand a lot of what is being said in this thread as it is fairly technical. Just looking for a simple answer. Thank you.
