Topic: Fireface UFX Passing only 9 and 10 to DAW
Neither Vegas nor Sonar receive input from 11 and 12. They both receive it fine from 9 and 10. Cables all work, UFX displays the input signal from 11 and 12, TotalMix displays the input from 11 and 12, and DUREC can record all of the channels. Yet, I cannot record into Vegas or Sonar on 11 and 12.
To rule out an issue with my UFX, I connected it to an older computer and 11 and 12 work! I went as far as installing the driver version from the working computer to the non-working one with no change. I also installed Vegas 12 on both machines, and 11 and 12 also worked on the old computer (but not the new) so that wasn't a factor. Both computers are running Windows 10 1909.
Any advice? Please let me know if you need more detail.
Thanks,
Dale
