Windows 10 21H1 - sometimes I had audio glitches.
The following combination of changes brought stability and very low DPC latencies also for nVidia
1. Mainboard: Supermicro X10SRi-F - downgrade BIOS from v3.1c to v2.0b (from 02.05.2017)
This is the BIOS version with support for E5-1650v4 (Broadwell-EP) and DDR4-2400, but without firmware upgrades for Spectre and Meltdown. I wanted to be able to deactivate those firmware upgrades entirely to get maximum performance of the CPU again.
2. GPU: MSI GeForce RTX 2070 SUPER Gaming X Trio - downgrade to nVidia driver version 442.74.
According to this nVidia forum thread this driver version has low DPCs: https://www.nvidia.com/en-us/geforce/fo … h-dpc-lat/
3. Windows 10 Pro 21H1
a) disabling CPU firmware upgrades for Spectre and Meltdown
Using the tool InSpectre: https://www.grc.com/inspectre.htm
I do not recommend disabling the fixes if your system is connected to the internet, I disabled it only for testing.
b) using energy profile "Ultimative Performance" (already done b4, mentioned for completeness)
With Admin rights: powercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61 and reboot.
Then choose it and usual tweaks: stop dia show, deactivate selective USB power saving
c) optimize Windows scheduler for background services (already done b4, mentioned for completeness)
4. USB3.0 card: Sonnet Allegro Pro USB3.0 PCIe, 4x Fresco Logic 1100 Chipset
Using Win10 21H1 Fresco Logic USB 3.0 eXtensible Hostcontroller driver 10.0.19041.1081 (already done b4, mentioned for completeness)
5. RME UFX+, firmware v46, MADIface driver v0.9735, connected to Sonnet Allegro (already done b4, mentioned for completeness)
ASIO Buffersize: 32 samples @44.1
6. Deinstalled Kaspersky Internet Security, reactivated Windows Defender (already done b4, mentioned for completeness)
LatencyMon: much lesser DPC/lag when accessing the network/internet with Firefox and no audio drops
7. Results during/after 1.5h of music playback
- MusicBee 3.4.7805 using the RME MADIface ASIO driver: no audio glitches anymore
- RME driver settings: not a single CRC transport error
- LatencyMon v7.0:
- nVidia Windows Kernel mode driver (nvlddmkm.sys): highest DPC execution time around 400us, with Firefox up to 700us
- it's even possible to use Outlook and Firefox to access network, DPC exec times of nvlddmkm.sys stay under 850us
This looks very promising, same good performance like initially under Windows 7 it appears to me.
Not sure which change or optimization exactly fixed the issue with random audio glitches w/o any deterministic behaviour.
I assume that the sum of those optimizations finally lead to optimum results.
BTW .. to stay on Win 10 Pro 21H1 I added these two registry keys according to information found here: https://www.computerworld.com/article/3 … lling.html
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate
- add DWORD TargetReleaseVersion = 1
- add String TargetReleaseVersionInfo = "21H1"
Don't know whether this really works, lets see. 21H1 works quite nice, so I want to stay with it a little longer.
LatencyMon 7.0 results - 30 min - Interrupt to user process latency - meltdown spectre DISABLED:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:30:07 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: SUPERMICRO
OS version: Windows 10, 10.0, version 2009, build: 19043 (x64)
Hardware: Super Server, Supermicro
CPU: GenuineIntel Intel(R) Xeon(R) CPU E5-1650 v4 @ 3.60GHz
Logical processors: 12
Processor groups: 1
RAM: 32641 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 416,30
Average measured interrupt to process latency (µs): 2,599883
Highest measured interrupt to DPC latency (µs): 413,80
Average measured interrupt to DPC latency (µs): 0,839820
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 236,405833
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,054036
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,057049
ISR count (execution time <250 µs): 2131542
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 412,58750
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0,033636
Driver with highest DPC total execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in DPCs (%) 0,071029
DPC count (execution time <250 µs): 6311634
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 18
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: magentacloud.app.exe
Total number of hard pagefaults 7279
Hard pagefault count of hardest hit process: 2099
Number of processes hit: 27
PER CPU DATA
CPU 0 Interrupt cycle time (s): 43,349071
CPU 0 ISR highest execution time (µs): 236,405833
CPU 0 ISR total execution time (s): 12,291941
CPU 0 ISR count: 1836481
CPU 0 DPC highest execution time (µs): 412,58750
CPU 0 DPC total execution time (s): 14,845943
CPU 0 DPC count: 6187509
CPU 1 Interrupt cycle time (s): 5,488060
CPU 1 ISR highest execution time (µs): 181,279167
CPU 1 ISR total execution time (s): 0,001272
CPU 1 ISR count: 75
CPU 1 DPC highest execution time (µs): 79,870833
CPU 1 DPC total execution time (s): 0,001748
CPU 1 DPC count: 385
CPU 2 Interrupt cycle time (s): 5,930825
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 336,354167
CPU 2 DPC total execution time (s): 0,082419
CPU 2 DPC count: 19025
CPU 3 Interrupt cycle time (s): 5,974855
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 60,0350
CPU 3 DPC total execution time (s): 0,003599
CPU 3 DPC count: 823
CPU 4 Interrupt cycle time (s): 5,652543
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 126,70
CPU 4 DPC total execution time (s): 0,028076
CPU 4 DPC count: 7445
CPU 5 Interrupt cycle time (s): 5,196379
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 60,40250
CPU 5 DPC total execution time (s): 0,002894
CPU 5 DPC count: 417
CPU 6 Interrupt cycle time (s): 6,671963
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 305,37750
CPU 6 DPC total execution time (s): 0,223627
CPU 6 DPC count: 51372
CPU 7 Interrupt cycle time (s): 5,211727
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 40,520833
CPU 7 DPC total execution time (s): 0,000521
CPU 7 DPC count: 130
CPU 8 Interrupt cycle time (s): 6,010731
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 56,104167
CPU 8 DPC total execution time (s): 0,041695
CPU 8 DPC count: 8519
CPU 9 Interrupt cycle time (s): 5,868678
CPU 9 ISR highest execution time (µs): 4,604167
CPU 9 ISR total execution time (s): 0,026618
CPU 9 ISR count: 89959
CPU 9 DPC highest execution time (µs): 334,213333
CPU 9 DPC total execution time (s): 0,016578
CPU 9 DPC count: 2694
CPU 10 Interrupt cycle time (s): 6,481266
CPU 10 ISR highest execution time (µs): 4,530833
CPU 10 ISR total execution time (s): 0,052143
CPU 10 ISR count: 205027
CPU 10 DPC highest execution time (µs): 303,55250
CPU 10 DPC total execution time (s): 0,141846
CPU 10 DPC count: 30990
CPU 11 Interrupt cycle time (s): 5,557577
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 334,1550
CPU 11 DPC total execution time (s): 0,014753
CPU 11 DPC count: 2343
LatencyMon 7.0 results - 30 min - Interrupt to user process latency - meltdown spectre ENABLED RUN 1/2:
CONCLUSION
LatencyMon has been analyzing your system for 0:30:08 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Processor groups: 1
RAM: 32641 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 707,90
Average measured interrupt to process latency (µs): 2,590089
Highest measured interrupt to DPC latency (µs): 705,80
Average measured interrupt to DPC latency (µs): 0,852438
REPORTED ISRs
Highest ISR routine execution time (µs): 229,550833
Highest reported total ISR routine time (%): 0,052770
Total time spent in ISRs (%) 0,055845
ISR count (execution time <250 µs): 2258879
REPORTED DPCs
Highest DPC routine execution time (µs): 708,0950
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 442.74 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,031620
Total time spent in DPCs (%) 0,068360
DPC count (execution time <250 µs): 6150310
DPC count (execution time 500-10000 µs): 44
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 581
Hard pagefault count of hardest hit process: 427
Number of processes hit: 17
PER CPU DATA
CPU 0 Interrupt cycle time (s): 42,643589
CPU 0 ISR highest execution time (µs): 229,550833
CPU 0 ISR total execution time (s): 12,002991
CPU 0 ISR count: 1793662
CPU 0 DPC highest execution time (µs): 708,0950
CPU 0 DPC total execution time (s): 14,277508
CPU 0 DPC count: 6036932
CPU 1 Interrupt cycle time (s): 5,289265
CPU 1 ISR highest execution time (µs): 0,969167
CPU 1 ISR total execution time (s): 0,000022
CPU 1 ISR count: 53
CPU 1 DPC highest execution time (µs): 42,101667
CPU 1 DPC total execution time (s): 0,000521
CPU 1 DPC count: 152
CPU 2 Interrupt cycle time (s): 6,537531
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 287,810833
CPU 2 DPC total execution time (s): 0,235473
CPU 2 DPC count: 52589
CPU 3 Interrupt cycle time (s): 5,552983
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 54,80750
CPU 3 DPC total execution time (s): 0,001008
CPU 3 DPC count: 244
CPU 4 Interrupt cycle time (s): 6,056071
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 56,751667
CPU 4 DPC total execution time (s): 0,048572
CPU 4 DPC count: 11245
CPU 5 Interrupt cycle time (s): 4,949978
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 55,44750
CPU 5 DPC total execution time (s): 0,000229
CPU 5 DPC count: 38
CPU 6 Interrupt cycle time (s): 6,026311
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 55,873333
CPU 6 DPC total execution time (s): 0,039001
CPU 6 DPC count: 8693
CPU 7 Interrupt cycle time (s): 5,115892
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 18,668333
CPU 7 DPC total execution time (s): 0,000160
CPU 7 DPC count: 58
CPU 8 Interrupt cycle time (s): 5,836293
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 284,620833
CPU 8 DPC total execution time (s): 0,025021
CPU 8 DPC count: 5938
CPU 9 Interrupt cycle time (s): 5,478010
CPU 9 ISR highest execution time (µs): 2,64250
CPU 9 ISR total execution time (s): 0,001762
CPU 9 ISR count: 6708
CPU 9 DPC highest execution time (µs): 52,460833
CPU 9 DPC total execution time (s): 0,003415
CPU 9 DPC count: 547
CPU 10 Interrupt cycle time (s): 6,733354
CPU 10 ISR highest execution time (µs): 5,26250
CPU 10 ISR total execution time (s): 0,112668
CPU 10 ISR count: 458456
CPU 10 DPC highest execution time (µs): 285,269167
CPU 10 DPC total execution time (s): 0,174869
CPU 10 DPC count: 27488
CPU 11 Interrupt cycle time (s): 5,67750
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 60,13250
CPU 11 DPC total execution time (s): 0,027317
CPU 11 DPC count: 6430
LatencyMon 7.0 results - 30 min - Interrupt to user process latency - meltdown spectre ENABLED RUN 2/2:
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 32641 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 296,40
Average measured interrupt to process latency (µs): 2,596561
Highest measured interrupt to DPC latency (µs): 277,70
Average measured interrupt to DPC latency (µs): 0,84940
REPORTED ISRs
Highest ISR routine execution time (µs): 229,055833
Highest reported total ISR routine time (%): 0,052846
Total time spent in ISRs (%) 0,055957
ISR count (execution time <250 µs): 2267231
REPORTED DPCs
Highest DPC routine execution time (µs): 293,659167
Highest reported total DPC routine time (%): 0,031767
Total time spent in DPCs (%) 0,068712
DPC count (execution time <250 µs): 6178474
DPC count (execution time 500-10000 µs): 22
Total number of hard pagefaults 50
Hard pagefault count of hardest hit process: 33
Number of processes hit: 3
PER CPU DATA
CPU 0 Interrupt cycle time (s): 42,637404
CPU 0 ISR highest execution time (µs): 229,055833
CPU 0 ISR total execution time (s): 12,027837
CPU 0 ISR count: 1804253
CPU 0 DPC highest execution time (µs): 282,60250
CPU 0 DPC total execution time (s): 14,379986
CPU 0 DPC count: 6071703
CPU 1 Interrupt cycle time (s): 5,260888
CPU 1 ISR highest execution time (µs): 0,0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 33,305833
CPU 1 DPC total execution time (s): 0,000130
CPU 1 DPC count: 34
CPU 2 Interrupt cycle time (s): 6,450142
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 293,659167
CPU 2 DPC total execution time (s): 0,225081
CPU 2 DPC count: 50424
CPU 3 Interrupt cycle time (s): 5,555806
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 56,28750
CPU 3 DPC total execution time (s): 0,000911
CPU 3 DPC count: 190
CPU 4 Interrupt cycle time (s): 6,102325
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 58,118333
CPU 4 DPC total execution time (s): 0,048679
CPU 4 DPC count: 11436
CPU 5 Interrupt cycle time (s): 4,917506
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 18,858333
CPU 5 DPC total execution time (s): 0,000041
CPU 5 DPC count: 22
CPU 6 Interrupt cycle time (s): 5,966442
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 52,566667
CPU 6 DPC total execution time (s): 0,038819
CPU 6 DPC count: 8715
CPU 7 Interrupt cycle time (s): 5,114193
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 35,470833
CPU 7 DPC total execution time (s): 0,000347
CPU 7 DPC count: 55
CPU 8 Interrupt cycle time (s): 5,862124
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 59,504167
CPU 8 DPC total execution time (s): 0,025374
CPU 8 DPC count: 5535
CPU 9 Interrupt cycle time (s): 5,436859
CPU 9 ISR highest execution time (µs): 3,290
CPU 9 ISR total execution time (s): 0,001423
CPU 9 ISR count: 5546
CPU 9 DPC highest execution time (µs): 54,405833
CPU 9 DPC total execution time (s): 0,002945
CPU 9 DPC count: 466
CPU 10 Interrupt cycle time (s): 6,742002
CPU 10 ISR highest execution time (µs): 4,325833
CPU 10 ISR total execution time (s): 0,11350
CPU 10 ISR count: 457432
CPU 10 DPC highest execution time (µs): 289,1450
CPU 10 DPC total execution time (s): 0,166749
CPU 10 DPC count: 27070
CPU 11 Interrupt cycle time (s): 5,641722
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 288,721667
CPU 11 DPC total execution time (s): 0,021753
CPU 11 DPC count: 2846
BR Ramses - UFX III, ADI-2 Pro FS R BE, M-1620 Pro D, 12Mic, XTC, RayDAT, Win10, X10SRi-F, E5-1680v4
