Topic: Upgrade to UFX II from Babyface Pro, glitches galore
I just installed the the UFX II after years of successfully running the Babyface Pro. Now I get glitches every second on recordings which make the interface impossible to use. I updated to latest drivers, but could not run the flash utility, even if I allowed it permissions manually. Glitches are present in both Ableton and Bitwig.
System is Macbook Pro 16" running latest Catalina. No changes since running Babyface, using the same Caltech Digital Thunderbolt hub to run it I used with the Babyface Pro.
Any help?
Cheers,
Hainbach
