Topic: adi-192 DD
Hello.
I have two ADI-192 DD units. Today there was a power outage that lasted for about 20 minutes. Both units were on at the time of the outage, when power returned only one powered back on, the other one didn’t. I tried to flip the front panel power switch on and off a few times but it did t work.
Could it be a power supply failure? These two units have never had a glitch before...
Any suggestions? I am in Los Angels, maybe you have some authorized tech shop that I could go to..
Thank you in advance!
RM
Re: adi-192 DD
Anyone....?
I was really hoping for MC to chime in..
Re: adi-192 DD
Seems likely that the PSU will need service. There is no official RME service center in LA, but Audio Rehab in Burbank can help you.
Re: adi-192 DD
Thank you Jeff.
Would it be possible to order the PSU from RME assuming it’s a module?
I have a friend in the industry who’s extremely competent. He would replace the PS module and save me tons of cash.. (AR in Burbank is 2-3 weeks behind on the bench unless one pays additional $$ to rush an order, plus the bench fee..).
I will take a look inside the unit tomorrow and see if I can spot any failed parts, like caps.
Meanwhile, thank you!
-RM
Re: adi-192 DD
If you are in USA you can buy the NT-RME-1 power supply part for the ADI-192DD here:
https://www.rme-usa.com/power-supplies.html
Please note that while it should be a simple replacement for the tech, instructions/schematics are not available.
Re: adi-192 DD
It is unlikely but Afaik there is a fuse on the power supply that might just be blown.
Re: adi-192 DD
Guys, thank you so much for the help.
I’ll check the fuse and PSU this morning and take it from there. I would LOVE IT if it were just a fuse....
Re: adi-192 DD
Fuse checked out fine. I just ordered the PSU from RME, and hope to get it delivered soon.
Thank you guys for the help, I’ll post the outcome once the replacement is installed.
RM
Re: adi-192 DD
An update, in case some of you guys use the same unit;
I ordered and quickly received a new power supply from RME/Synthax USA. I installed it myself .. piece of cake!
Thank you Jeff for your prompt help, you guys are the best!
Cheers,
RM
