Topic: TotalMix keyboard shortcuts for switching snapshots etc?
Are there any keyboard shortcuts for switching snapshots and toggling basic control room functions (talkback, etc)?
RME User Forum → TotalMix FX → TotalMix keyboard shortcuts for switching snapshots etc?
TotalMix FX, Options, ARC and Key Command Settings. Further TM FX hotkeys are described in the manual.
Cool thanks. Sorry to ask such a dumb question but I don't have my UFX with me ATM (it's been in China since February because of Covid-19 and I still don't know when I'll be able to go back to get it so I'm probably getting a new one and sell the old one later), otherwise I would have checked through the Totalmix FX menus.
I checked the manual earlier and couldn't find the relevant info, but just now I did, it say:
ARC & Key Commands. Opens a window to configure the programmable buttons of the Standard, Advanced and Advanced Remote USB, and of the computer’s keyboard keys F4 to F8.
There are only five hard-coded hotkeys available for users to configure? That's a bit disappointing considering there are, for example, 8 snapshots (not 5) and many other functions that users might want to be able to trigger/toggle from their keyboard. I guess I guess I'll stick to using MIDI instead.
Did you miss chapter 25.9, Hotkeys and Usage? There are some more hotkeys in there.
BTW, I wish you good luck for going back to China soon. I was separated from my family since March and am currently in local quarantine in Bangkok. Hope to see them soon. These are crazy times for most of us.
Sure, I did notice that section but those shortcuts are hard-coded and didn't do what I wanted. I understand TotalMix was designed to be controlled by MIDI for some good reasons (e.g. the window doesn't need to be focused), so I'll probably end up buying one of those nice and small Novation controllers and use that.
Likewise! Luckily Spain is my home, and that's where I'm now I had worked in China for nearly ten years until February. I returned to Spain to see my parents for a few weeks, like I used to do once every year, and then I was unable to return. Basically I've been forced to start a new life in Spain, and that's OK because I kinda missed home. I'm still renting my apartment in China (luckily it's not expensive) and need to go back just to tie up loose ends, wire my savings over to Spain, rescue a few valuables (including my UFX and my Babyface Pro of course) and leave permanently. Crazy times indeed.
TotallMix shortcuts only works when its window is in focus.
Use Keyboard Maestro to send the MIDI to TotalMix with your desired shortcuts. That way you can control TotalMix even it's in background.
Set "Keyboard Maestro" as input ports in Option -> setting -> MIDI, and send note-off signal on note 54-61 for snapshot 1-8.
No dedicated shortcuts nor access from menu for snapshots unfortunately.
On Mac - You can also do this...
I prefer this method, as it doesn't need to have any 3rd party software installed/or any additional services/apps running.
1) Save your Snapshots to your default config dir via "File - Save Snapshot as..."
2) give your snapshots a proper naming - like this f.ex:
1_Snap.tmss
2_Snap.tmss
3_Snap.tmss
3) Open the (Siri-)Shortcuts App and create a new one
4) On the right side from Apps Section, drag "execute Applescript" snippet into main Section
5) Paste the following code into the Applescript Code Editor (opens the snapshot file beginning with "1")
#if TM App is not opened, open it
tell application "Totalmix" to run
try
tell application "System Events"
# Bring Totalmix App to the front
tell process "TotalMix FX"
set frontmost to true
end tell
# Open the "Load Snapshot..." Window via Hotkey (Command+O) in my case
# key code 31 = "O" on Keyboard
key code 31 using command down
# wait for Open Dialog window 1 second
delay 1
# Press 1 on Keyboard (18 = "1") - selects the first file which name begins with 1 - (1_Snap.tmss) in this example
key code 18
# Press Return (36 = "Return") on Keyboard - the OK Button in the Dialogue Window
key code 36
end tell
# some basic Error handling
on error errMsg
display dialog "Error: " & errMsg
end try
6) click on the top right "i"-icon and check that "Use as fast action" and "Menu Services" is enabled
7) Push the Button "assign a Keyboard Hotkey" and enter your preferred Key-Combination to it
7) On first launch, you should get a message if your Shortcut is allowed to execute Applescript
8) Save it and it and should work. Even if the Shortcut App is closed, your custom Hotkey triggers always the script. Doesn't matter if Totalmix is not in focus or minimized.
You can check this in Mac-Systemprefs -> Keyboard -> Keyboard-Hotkeys -> Services -> Hotkeys
My app ControlPilot makes available many of the Control Room features, Mute Groups, Cue and also Snapshot recall as keyboard shortcuts on macOS.
gtichy wrote:No dedicated shortcuts nor access from menu for snapshots unfortunately.
Yes, this is an amazing piece of software.
...just to add: Everything, you can control via MIDI/Mackie also works via (Siri) Shortcuts.
All you need is to install gbevin's little sendmidi binary:
https://github.com/gbevin/SendMIDI
Best practice is to create a seperate IAC Port on Mac. F. ex. "ToTMX".
Assign it to a MIDI Controller in Totalmix. Check Mackie Protocol.
Create a Shortcut script with "Execute Shell-Script" action with following content:
Ex. 1: If you want to toggle SpeakerB:
/usr/local/bin/sendmidi "dev ToTMFX on 50 0"
Ex. 2: If you want to activate Snapshot 6:
/usr/local/bin/sendmidi "dev ToTMFX on 61 0"
Ex. 3: If you want to activate Snapshot 5:
/usr/local/bin/sendmidi "dev ToTMFX on 60 0"
... and so on...
Works like a charm (even via Siri - Voice Input or triggered from Homekit Scenes/Actions)
And the best: Totally opensource and free
Just ask me, if someone needs help with this method.
I couldn't find it in the manual. but would the group mute buttons be automatable? I'm trying to create a script to mute/unmute the main outputs and the headphones to when I need to switch between them
In manual search for:
- MIDI Control
- OSC Control
- ARC & Key Commands
Yes - you have multiple Options. At least 3 ideas, came in my mind, but there should be other ways, too...
1) MIDI:
- Assign the states of your Mutegroups to different Snapshots in TM
- Trigger them via MIDI (Mackie Protcol Buttons F1-F8 (dont remember the exact Notes atm, but easy to find out))
2) OSC:
- see the OSC Table Reference (link in manual) which OSC Commands have to be sent and how to enable the Controller in TM
3) Key Commands:
- in TM the F4-F8 keys have to be assigned to Toggle the Mutegroups
- by emulating Key-presses (F4-F8) via whatever script language
- a basic example via applescript, is in my post #8
thanks a lot maggie
I'm using Karabiner Elements to map the obsolete Eject key on my magic keyboard to f5, and it worked. two questions arise:
1) now how can I make f5 do two simultaneous commands (toggle mute Group 1 and toggle mute Phones 1 - so I can alternate between them)?
2) how would I go about making it work with Totalmix in the background and not 'activated'? is that possible?
Two simultaneous actions for one key would not make a sense in any software (not only in TM).
The only idea, i have, could be remapping your eject key to trigger F4 and F5 at the same time, where you could have set up in TM F4 for toggle Mute Group1 and F5 for toggle Phones 1. But this would lead to "out of sync" if the previous states differ.
https://hidutil-generator.netlify.app should give the basic usage how you could do this (even without karabiner) - but afaik, it could be done with karabiner, too.
Afaik - not possible on via the "common" way, as only the frontmost App has access to the keyboard. An "uncommon" (but possible) way would be if an app (dont know if karabiner hast this possibility now), which requests the "allow to keyboard access in background capability". But anyhow, to trigger the F4, F5 Commands in Totalmix, TM would have to be set as frontmost Application first.
I would recommend to map the Eject Key however (= via whatever SW) to be able to send OSC Commands to TM (As it always responds to OSC Messages, even in Background).
Assign it to a MIDI Controller in Totalmix. Check Mackie Protocol.Create a Shortcut script with "Execute Shell-Script" action with following content:
... and so on...
Thank you so much maggie!
I tried to get it to work for sooo long and finally I found your post and it works flawlessly.
I couldn't seem to figure out the right command; lastly I thought it should be
sendmidi dev "IAC Driver BUS 1" off 54 0
mailny because of another forum post I found earlier where the poster said the protocol has to be enabled and one has to send an off signal with 0 velocity to make it work. I also tried to specifically write the extra 0 for channel 1
sendmidi dev "IAC Driver BUS 1" off 0 54 0
but nothing worked. Then I came across your post here and the first thing I did was to create a dedicated BUS for TMX in 'Audio MIDI Setup > MIDI Studio > IAC Driver' and then tried your command
sendmidi dev "IAC Driver TMX" on 54 0
and tada.
Before that I tried with the stock 'IAC Driver Bus 1' basically any combination of
on/off 0/- 54 0/1/176/f 1.0/f 0.0/ b on/ b off/...
there is, so I'm pretty sure I also came across your command;
so I think the extra BUS did the trick, but I'm not sure and won't mess with it anymore.
I just wanted to thank you very much here! <3
Best regards Q
PS: My personal setup is totally based on
skhd https://github.com/koekeishiya/skhd
yabai https://github.com/koekeishiya/yabai
and sketchybar https://github.com/FelixKratz/SketchyBar
were I can now use two simple skhd-hotkeys
hyper - f16 : sendmidi dev "IAC Driver TMX" on 54 0
hyper - f17 : sendmidi dev "IAC Driver TMX" on 55 0
to control my two most used snapshots.
Perhaps these three programs are interesting to you as well.
I cannot live without them anymore really.
Hi qns,
thanks for the three programs. Will look into them deeper, soon.
Nice, you could manage this at all
Maybe to add, regarding your earlier problems with sendmidi:
The "extra" Bus "TMX" is just meant as a visual "reserved for TM" flag. Especially if you use other IAC Busses in other Apps/DAWs, to avoid confusion...
So it should work with "IAC Driver Bus 1", too (as the default AMS uses it). Just note: its case sensitive - so, maybe your Problem was related to this? As i see, you tried: "IAC Driver BUS 1"...
Anyhow, just enter this to get the correct naming of your current ports:
sendmidi list
Or
sendmidi -h
to get a detailed explanation of the possibilities.
regards, maggie33
