1
Topic: Hardware FX Chain Loopback Question
Hi.
I am using a Fireface UFX II and watched some videos and skimmed the web but couldn't find an answer so here it comes:
I have three hardware FX devices (Saturator, EQ, Compressor).
Currently they are routed via TotalMix EQ->Comp->Sat->AES loopback because I was hoping to be able to save redundant DA/AD-conversions like I'm getting when using this FX chain in the DAW with Hardware Inserts as this way the DAW/Fireface converts before and after every hardware device.
In a nutshell:
Do I still get 6 conversions (DA->EQ->AD->DA->Comp->AD->DA->Saturator->AD) as in the DAW (if I'm not mistaken) or just 2 (DA->EQ->TotalMix Routing->Comp->Saturator->AD) as with an actual patchbay?
Thank you very much.
Re: Hardware FX Chain Loopback Question
Every TM FX controlled I/O is A/D or D/A (unless AES, ADAT, SPDIF). There is no analog routing within our units.
3 (edited by Bo 2020-11-30 05:54:07)
Thanks MC. That's a pitty, I thought I had a good idea. Any other benefits, latency-wise maybe, in the TotalMix way to console me? If not I will switch back to hardware inserts in the DAW as these have the advantage of parallel processing.
Cheers.
Edit: And now that this has been clarified, just to be sure, is the loopback from AES/ADAT outputs to their respective inputs yet another conversion?
I gladly repeat:  'is A/D or D/A (unless AES, ADAT, SPDIF)'. What 'conversion' should that be?
None, I guess, just wanted to be sure and since I'm rather a producer than an engineer I have to ask yet again the final question: Does a loopback from AN 1/2 OUT to AN 1/2 IN conversions? Your answer suggests that but firstly the diagrams in the manual neither show it nor is it mentioned anywhere and if I test record via loopback I seem to get just about 1 sample latency, which is far less than the expected 3ms according to the manual.
Thank you very much again.
6
Do you talk about the Loopback function of TotalMix FX? That one is digital and inside the hardware, with no analog conversion.
If you connect analog in to analog out with a cable (loopback) then you might not be able to measure delay as the DAW compensates for it.
I ment the loopback function. Thanks, everything is clear now.
