Topic: Having trouble obtaining a signal from the Digiface USB
Hello Everyone,
I'm trying to connect my Yamaha 01v96 to a Digiface USB, but I have troubles obtaining any audio signal form the console. I'm using a MY16At card to connect the optical outputs of the mixer to the Digiface, and I suspected that the problem might be related to the configuration of the card. Yet, after reading numerous forums I have to say that the settings of the mixer appear to be correct. For that reason I would like to check up with you guys and see whether I have also connected the Digiface correctly.
I should say that I did read the manual, which is very comprehensive, yet things are still going wrong somewhere.
The current settings of the Fireface are as follows:
Optical output 1 till 4 are set to ADAT
The sample rate is 44.1kHz
Clock source is set to Optical In 1
Current Clock: ADAT 1 In
Input Status:
Optical In 1 Sync 44.1 kHz ADAT the same goes for Optical In 2 and 3.
It seems that the console and the Digiface are communicating, but there is audio signal coming form the mixer. As for the DAW, I use Logic Pro X with macOS High Sierra.
Do you guys have any idea what the problem might be and how it can be fixed?
Cheers!
