Topic: Problem with output 7/8
i have problems with PAN in my UCX
i checked all the outputs in totalmix and all is ok. But in my headphones the pan its not correct.
Do you know how can i factory reset all the outputs?
im using Ableton Live for output 7 8 and its working good.
or how can i reset the hardware ?
2 (edited by ramses 2020-12-19 10:13:54)
Re: Problem with output 7/8
TM FX -> Options -> Reset Mix -> Total Reset
And if your DAW supports ADM, then additionally:
TM FX -> Options -> Reset Mix -> Set Inputs Mono and Outputs Stereo (ADM)
See also manual ch. 27.1
https://www.rme-audio.de/download/fface_ucx_d.pdf
https://www.rme-audio.de/download/fface_ucx_e.pdf
its not working....
in Total Mix te Pan is Center Ok with levels but in the jack output 7/8 i hear only 50%  for Channel 7.
"hardware problems???"
the issue isn't quite clear - do you also see different levels in Totalmix?
There is a Reset in the Options menu.
I have the same problem. Although the levels in TM are the same I get only 50% on Channel 7. When I route to 1/2 everything is fine.
6
If TM FX shows correct levels then the interface output seems defecrtive and needs repair.
