Topic: FF400 & apple M1 big sur no midi
hello all, happy to be back to the RME community, got a FF400 connected to my M1 mbp running big sur (obviously) and sofar everything is great, except that i cant see the midi ports anywhere. is this a known issue?
many thanks,
Re: FF400 & apple M1 big sur no midi
There is a little free software called Midi-Monitor.
It does write down every incoming Midi message, try it out.
thank you very much for replying. the problem is that the ports of the FF are not recognized by my M1 mbp so monitoring incoming midi is cant be done, FWIW i checked and the midi device file is installed in the ~/library/audio/ path but is still not recognized.
The MIDI driver definitely works on M1. This looks like the usual issue with Macs - Audio MIDI Setup failing to show the MIDI ports. Helping might:
- Select the Default configuration or  a new one
- Delete alle MIDI devices and start a search to refresh the view
- Make the window full screen, the new MIDI device might be out of sight
@MC thanks for that, midi just appeared out of nowhere at some point(possibly 2 days and 2 fresh restarts later) and all is working well.
Nice your FF400 is running on a MBP M1
How did you connect? Which adapters did you use?
Thinking to get a Mac mini M1...
http://www.nantschev.com
http://www.crystalhorizon.at
Just want to report my FF400 is running rock solid on my new Mac mini M1 with two Adapters: USBc->Thunderbolt2-Thunderbolt->to Firewire
The FF400 is the most solid piece of gear in my studio. thanks to the team and RME doing such amazing products.
For me its like the Mercedes of sound cards ))
