Topic: Connecting Issues with modern notebooks
Hey People,
I couldn't find a proper thread - I've got the question: how to connect my Interface to my Notebook
Sounds easy? Well I've got a lot of Issues since I'm using my new notebook with Windows 10 and Cubase 11.
I'm using the Fireface UFX+. So I think this is no Driver Issue, because Windows 10 should cause no problems...
I got about five blue screens with the message "multiple_irp_complete_requests" after I touched the USB cable a little bit. When I do this, it is disconnecting and reconnecting fastly, the cable doesn't seem to be ülugged in too firmly...
Since I only got 2 USB ports and need to connect a lot of things like dongle, e-drums, interface and in best mouse and keyboard when I record, I was thinking if I can connect the Fireface via USB-C or Thunderbolt.
But as far as I was looking, there is no cable from the "old, big" thunderbold port on the backside to the Standard USB-C-Thunderbolt port on my Notebook. Do you know one? And would this even work?
Otherwise I could use a Thunderbolt or USB-C Usb-Hub to connect the the Fireface and the other stuff, I think this has to work, because some Notebooks (like all apple notebooks) just have these ports - but can you recommend some Hubs, did you test some?
Or should I try a new cable from the interface to the USB-C port?
Since newer notebooks JUST have USB-C ports, there have to be some people here with the same issues... are they?
I just want my Fireface to work as great on the new notebook as it did on the old one!
Would be great to hear from you
thanks,
Jakob
