Topic: UFX suddenly has no output on USB file playback
For a long time, I've used a USB flash drive for storing files on it, and use my UFX to play it back, never had any problems with it.
Yesterday, when I wanted to play back a file for a customer, it suddenly didn't work. It showed all the files on the drive, I was able to select them and play them, and the counter also indicated that they were playing back, but I could hear no sound at all.
Other sound sources and sound coming from my computer via FireWire still worked 100% perfectly.
I was looking through TotalMix and the manual, but didn't find anything that involves this problem.
I regularly switch between two different operating systems, and at times get messages after boot-up that the configuration has changed and maybe it has screwed up some of the settings because of this.… but I reloaded my workspace and it still didn't help, so I'm wondering what I might be missing here.
Any input on this would be greatly appreciated!
EDIT: I just found it, the play channel on the interface was set to OFF for some reason, I put it back to 1/2 on the interface, and it works again. Now I have a question: Is there a way to see/change this in TotalMix, or do I have to check this on the device itself?
