Topic: Automatic SMUX
I replaced my Digiface USB with a Raydat and have some questions regarding clocking/syncing:
- When I go 88.2 or 96k I have to set my converter manually to SMUX. Is it normal that there is no „signaling“ of SMUX? I looked in the manuals of Raydat, Digiface, Pulse16 (my converter) and other random converters/interfaces that came to mind, nowhere is it mentioned that you have to set SMUX manually except for the manual of the Dangerous Covert 8. So I guess it is due to ADAT, but I want to make sure.
- I have a tc clarity audio meter hooked up to SPDIF out (coax). I am not getting a „sync“ reading in the Raydat settings, probably because it’s an output, is that right? I only ask because I got such a reading with the Digiface and SPDIF optical, so I thought there may be some information going bidirectional. The tc meter works as expected and syncs to the correct SR.
Cheers
Vincent
