Topic: OSC To Two different TM windows
I run a system that includes an original UFX and a Madiface USB where Madiface is main interface and UFX is IO expansion via Adat and ADI-648. While I don’t send audio signals over USB to UFX I do have it connected to get Totalmix window control.
I use an old iPhone running Lemur to simply trigger Talkback button in UFX TM window and I wish to send 2 other commands to Madiface TM window to control Dim and Mono. I could not make it happen even though it appears Lemur is able to send to different port numbers per button and I had Lemur addressing the 2 different port numbers.
Is there anything about Totalmix FX architecture that might stop this from working?
Kind regards
Paul Najar
Jaminajar Music Production
www.jaminajar.com
