Topic: HDSP 9652 - driver 4.38 install problems
Hello
I have a rme 9652 (rev 108) with 4.36 driver version.
I'm trying install the new 4.38 driver and don't install and tell me that i don't have drivers on my card
Any Help please ?
Congratulations
Luis
windows 7/ 64bits
Re: HDSP 9652 - driver 4.38 install problems
Please be more specific. How exactly are you trying to install, what is the exact error message, and what's the operating sytem?
Hi Daniel
Thanks for your fast reply
I work with windows 7-64bits
I install like the others updates.I simply install the driver and its ok.
But with this driver (4.38), the installation tell me that its ok,  but i can't open the control panel of RME and Totalmix.
In Device manager the RME 9652 appears with a yellow signal and tell me that the card don't have driver.
I have try uninstall my 4.36 driver ---restard the pc --- and install the new driver ( 4.38 ) and its the same.
I Hope you understand my explanation.
Best Regards
Luis
windows 7/ 64bits
Does it work if you install 4.36 again? Is the card's firmware up to date?
Yes the card work well with 4.36 driver
what firmware you sugest ?
I thing the firmware its the last.
thanks
windows 7/ 64bits
6
Your Windows 7 seems not be be up to date with the latest certificates. Driver 4.37 and 4.38 no longer use the certificates that we used before because they expired. You have to update your Windows 7 or use driver 4.36 (btw, with a HDSP9632 there is no reason to update anyway).
And just to make this clear up-front: I was able to install driver 4.38 under Windows XP SP3, without doing anything special.
Thank Matthias
I go trying update my windows.
I give you news later.
Best Regards
Luis
windows 7/ 64bits
