Yes deinstallation of Kaspersky helps.
When I open the 63 URLs now, then I do NOT get audio drops, BUT LatencyMon reports high DPC for NVIDIA Windows Kernel Mode Driver. The value is under 1000 Microseconds nevertheless LatencyMon reports
"Your system seems to be having difficulty handling real-time audio".
Highest DPC routine execution time (µs): 746,668333
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 462.59 , NVIDIA Corporation
Ok, opening 63 webpages at once is quite a lot .. as long as audio is not impacted I can live with it.
_________________________________________________________________________________________________________
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:00:42 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: SUPERMICRO
OS version: Windows 10, 10.0, version 2009, build: 19043 (x64)
Hardware: Super Server, Supermicro
CPU: GenuineIntel Intel(R) Xeon(R) CPU E5-1650 v4 @ 3.60GHz
Logical processors: 12
Processor groups: 1
RAM: 32641 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 1377,50
Average measured interrupt to process latency (µs): 4,356054
Highest measured interrupt to DPC latency (µs): 1374,20
Average measured interrupt to DPC latency (µs): 2,133477
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 243,76250
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,061191
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,076548
ISR count (execution time <250 µs): 148856
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest reported total DPC routine time (%): 0,345885
Driver with highest DPC total execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in DPCs (%) 0,472761
DPC count (execution time <250 µs): 278117
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 23
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: firefox.exe
Total number of hard pagefaults 889
Hard pagefault count of hardest hit process: 823
Number of processes hit: 11
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2,359221
CPU 0 ISR highest execution time (µs): 243,76250
CPU 0 ISR total execution time (s): 0,071477
CPU 0 ISR count: 64139
CPU 0 DPC highest execution time (µs): 291,771667
CPU 0 DPC total execution time (s): 1,699870
CPU 0 DPC count: 202348
CPU 1 Interrupt cycle time (s): 1,293317
CPU 1 ISR highest execution time (µs): 240,58250
CPU 1 ISR total execution time (s): 0,281088
CPU 1 ISR count: 18670
CPU 1 DPC highest execution time (µs): 746,668333
CPU 1 DPC total execution time (s): 0,330613
CPU 1 DPC count: 28107
CPU 2 Interrupt cycle time (s): 0,611155
CPU 2 ISR highest execution time (µs): 5,086667
CPU 2 ISR total execution time (s): 0,007707
CPU 2 ISR count: 8418
CPU 2 DPC highest execution time (µs): 263,31250
CPU 2 DPC total execution time (s): 0,284701
CPU 2 DPC count: 30363
CPU 3 Interrupt cycle time (s): 0,192007
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 48,830
CPU 3 DPC total execution time (s): 0,004728
CPU 3 DPC count: 1127
CPU 4 Interrupt cycle time (s): 0,250611
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 54,65250
CPU 4 DPC total execution time (s): 0,011923
CPU 4 DPC count: 2910
CPU 5 Interrupt cycle time (s): 0,202680
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 51,106667
CPU 5 DPC total execution time (s): 0,003647
CPU 5 DPC count: 873
CPU 6 Interrupt cycle time (s): 0,239695
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 59,214167
CPU 6 DPC total execution time (s): 0,007020
CPU 6 DPC count: 1795
CPU 7 Interrupt cycle time (s): 0,215668
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 61,621667
CPU 7 DPC total execution time (s): 0,006209
CPU 7 DPC count: 1486
CPU 8 Interrupt cycle time (s): 0,383718
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 70,15750
CPU 8 DPC total execution time (s): 0,014483
CPU 8 DPC count: 2568
CPU 9 Interrupt cycle time (s): 0,213927
CPU 9 ISR highest execution time (µs): 3,425833
CPU 9 ISR total execution time (s): 0,003451
CPU 9 ISR count: 4968
CPU 9 DPC highest execution time (µs): 105,495833
CPU 9 DPC total execution time (s): 0,008166
CPU 9 DPC count: 1593
CPU 10 Interrupt cycle time (s): 0,278643
CPU 10 ISR highest execution time (µs): 9,7950
CPU 10 ISR total execution time (s): 0,024525
CPU 10 ISR count: 52661
CPU 10 DPC highest execution time (µs): 60,47250
CPU 10 DPC total execution time (s): 0,016942
CPU 10 DPC count: 3143
CPU 11 Interrupt cycle time (s): 0,208529
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 62,355833
CPU 11 DPC total execution time (s): 0,009504
CPU 11 DPC count: 1827
5 Minutes measuring, IDLE system, only Firefox opened
Average measured interrupt to DPC latency (µs): 1,075810
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:05:00 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Processor groups: 1
RAM: 32641 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 223,50
Average measured interrupt to process latency (µs): 2,859865
Highest measured interrupt to DPC latency (µs): 221,50
REPORTED ISRs
Highest ISR routine execution time (µs): 248,545833
Highest reported total ISR routine time (%): 0,032994
Total time spent in ISRs (%) 0,041625
ISR count (execution time <250 µs): 905856
REPORTED DPCs
Highest DPC routine execution time (µs): 284,823333
Driver with highest DPC routine execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Highest reported total DPC routine time (%): 0,282892
Total time spent in DPCs (%) 0,317247
DPC count (execution time <250 µs): 1368754
DPC count (execution time 500-10000 µs): 10
Process with highest pagefault count: tiworker.exe
Total number of hard pagefaults 3
Hard pagefault count of hardest hit process: 1
PER CPU DATA
CPU 0 Interrupt cycle time (s): 14,677396
CPU 0 ISR highest execution time (µs): 248,545833
CPU 0 ISR total execution time (s): 1,088362
CPU 0 ISR count: 606404
CPU 0 DPC highest execution time (µs): 284,823333
CPU 0 DPC total execution time (s): 10,896866
CPU 0 DPC count: 1314348
CPU 1 Interrupt cycle time (s): 3,187072
CPU 1 ISR highest execution time (µs): 242,84750
CPU 1 ISR total execution time (s): 0,348447
CPU 1 ISR count: 23108
CPU 1 DPC highest execution time (µs): 238,304167
CPU 1 DPC total execution time (s): 0,433088
CPU 1 DPC count: 37245
CPU 2 Interrupt cycle time (s): 1,047569
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 103,983333
CPU 2 DPC total execution time (s): 0,022113
CPU 2 DPC count: 3918
CPU 3 Interrupt cycle time (s): 0,977409
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 43,391667
CPU 3 DPC total execution time (s): 0,000518
CPU 3 DPC count: 148
CPU 4 Interrupt cycle time (s): 1,009815
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 132,489167
CPU 4 DPC total execution time (s): 0,010092
CPU 4 DPC count: 1869
CPU 5 Interrupt cycle time (s): 0,873836
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 20,31250
CPU 5 DPC total execution time (s): 0,000063
CPU 5 DPC count: 5
CPU 6 Interrupt cycle time (s): 1,030495
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 53,9950
CPU 6 DPC total execution time (s): 0,006642
CPU 6 DPC count: 1186
CPU 7 Interrupt cycle time (s): 0,910595
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 33,236667
CPU 7 DPC total execution time (s): 0,000082
CPU 7 DPC count: 12
CPU 8 Interrupt cycle time (s): 1,594524
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 45,470
CPU 8 DPC total execution time (s): 0,006023
CPU 8 DPC count: 1516
CPU 9 Interrupt cycle time (s): 0,952565
CPU 9 ISR highest execution time (µs): 2,806667
CPU 9 ISR total execution time (s): 0,002525
CPU 9 ISR count: 9794
CPU 9 DPC highest execution time (µs): 54,260
CPU 9 DPC total execution time (s): 0,000560
CPU 9 DPC count: 107
CPU 10 Interrupt cycle time (s): 1,193717
CPU 10 ISR highest execution time (µs): 4,730
CPU 10 ISR total execution time (s): 0,060252
CPU 10 ISR count: 266550
CPU 10 DPC highest execution time (µs): 71,280833
CPU 10 DPC total execution time (s): 0,050413
CPU 10 DPC count: 7931
CPU 11 Interrupt cycle time (s): 0,927681
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 70,213333
CPU 11 DPC total execution time (s): 0,002767
CPU 11 DPC count: 479
