Driver_fw_win_3125.zip It is the most current that I found in the
website that i download and install
I just bought a RME fireface400 and I see that it has been a problem to install it on 2 PCs that I have, I already download the most current driver, install the driver, restart, connect the interface and I do not see anything new hardware found or in any daw me The driver appears rme so only the interface is on but I can't do more, what can I do? the cable works in the 2 pc testing it with other firewire devices and the 2 pci e cards that I have firewire work correctly I know that the problem is with the installation when wanting to uninstall the driver it does not even appear in the uninstall programs section in the 2 pc, thank you very much if you help me get it started, greetings!
