Topic: Loose volume encoder
Hi everyone, I just picked up a new ADI-2, which is fantastic sound-wise.
However, the volume encoder seems very loose, to the point that it clicks in and out when the volume is adjusted. To be clear, this is unrelated to the push function of the encoder.
Please see this video: https://vimeo.com/573576228
You will see that I pulled on it showing the issue, then pushed the button, then did both, showing there are effectively three positions. Please can you let me know whether you have found similar issues.
Thanks. Matt
