davesollows wrote:I do find myself wanting to be able to monitor with rme's DSP integration.
What are your applications for this what do you want to do ?
davesollows wrote:With that in mind, is there an rme interface that has a couple of preamps with DSP...that I can hook up to Adat for the audio stream, but control the DSP via totalmix over usb/Ethernet?
In regards to the DSP: every RME recording interface with a built-in DSP chip and ADAT I/O.
See the Excel File in my blog article: https://www.tonstudio-forum.de/blog/ind … B-MADIfac/
But to control / operate it you need to connect it to the PC through USB/TB.
Only TotalMix FX can be remote controlled from another Windows computer in the network using TotalMix Remote.
davesollows wrote:The idea being I'd like to keep my audio interface to the computer through the digiface....but be able to access the totalmix fx control of the DSP in an Adat connected device, to the digiface. I just don't know if that's possible without using a seperate usb interface, that has the pre's with Dsp...
What for ? What exactly is the point ? May I ask the counter question why you don't sell the Digiface USB (or keep it as a backup) and just get a UCX II or UFX II ?
As nice as a connection via ADAT is, but ...
You only get 8 channels routed over it and that only at single speed (44.1/48 kHz).
Let's assume you want to connect a UCX II via ADAT to the Digiface USB. The UCX II is an interface with 20 I/O ports (40 in+out) but only one ADAT port. You would then have a lot of "waste", because you would have to make a selection 8 out of 20, what you want to have routed via ADAT.
With a recording interface with 2 ADAT ports like the UFX II you could route at least 16 of 30 channels via ADAT at single speed.
But honestly, make a UCX II or UFX II your main interface.
And in this point your request is not detailed enough, I don't understand at all why you want to do this necessarily over ADAT.
