Hi Michael,
how are you ? I do not understand what you want to achieve with it. For what use case / connection ?
You already have a 16-channel AD/DA converter with the SPL Madison.
I could think of that you want to integrate the ADI-2 FS in the hope that it enhances D/A quality for e.g. connecting your monitors and phones. But .. the MADIface Pro does not offer another digital I/O port to connect the ADI-2 FS digitally...
I went through your other postings and notice that you needed a lot of analog ports and also a few good preamps.
I would recommend you the combination of UFX+ and SPL Madison via MADI.
You can either sell the MADIface Pro for a good price (usually around 75% of Street price) or keep it for mobile use.
The UFX+ gives you
- MADI
- Flexibility in connecting to the computer: USB3, TB and even USB2 (then without MADI)
- four very nice Mic inputs that can also be used as line and instr inputs
- 8 more analog inputs and outputs independend of sample rate
- two excellent phones outputs
- DURec, Autoset, FX, stand-alone operation through display, direct connector for ARC USB
- AES and 2x ADAT where ADAT2 can be set to optical SPDIF
- all very compact in one rack unit, you can rack it together with your SPL, use a rack of 3 RUs for better airflow
And if you want the unique features of an ADI-2 Pro FS R BE, then you can add it at any time later and you have two ADAT ports and AES to connect it to the UFX+.
