Topic: Automatic zero or low latency on Babyface with DAW question?
Hi all,
Just a quick newbie question
On my Cubase, there is a speaker symbol for DAW monitors on each audio track. When I turn this on or off, does my RME recognize this and go off and on as well so I don’t a double reference which creates a chorusing effect?
I was looking for a switch on my Babyface for a Zero Latency mode on and off and haven’t found one. I assume therefore it is automatic?
If it is automatic (I do hear a sound even without the audio monitor in Cubase activated), if the monitor in Cubase is off, is this zero latency? Or is this low latency? Why I ask is that I understand that Zero Latency doesn’t add on to the PC’s CPU load. If it is Low Latency, then that is where the buffer setting on the PC comes in.
Having said that, when I have the audio track monitor in Cubase turned on, I am very impressed. I have the buffer set at 128 and I could go one more higher and am still ok. Nonissues with latency.
Thanks in advance!
