Topic: Sonnet Echo 11 Thunderbolt 4 and 2021 MacBook Pro causing aliasing
I wanted to see if anyone else has purchased this combo. The new Echo 11 Thunderbolt 4 hub is extremely unreliable. Devices and displays are not waking on connection or reboot, and specifically my UFX II has grating aliasing static on all audio recorded through the hub. Direct into the MacBook Pro it sounds as it should. Does anyone have a recommendation for a thunderbolt 4 hub that will work properly? It seems there are only two/three designs going around and the Sonnet version of this hub looked the best as it has a solid metal enclosure to sink heat.
