Topic: [SOLVED] Total Mix - Bleed Sound Between Channels
Hi everyone,
I am having the following issue:
I want to use my RME UCX in a 5.1 speaker setup. In the Sound / Midi Settings:
a) I chose my RME interface
b) in the output section to set the speakers, I chose 5.1 Surround configuration
c) and then setup the following Channel order:
Left Analog 1
Right Analog 3
Center Analog 2
LS Analog 4
Rs Analog 5
Sw Analog 6
Then in the Sound Midi Settings, by clicking on the Test button on each individual speaker I can see that, in the Total Mix, both L and C channels are bleeding/ feeding also into the R channel. The rest of the channels, including the R channel do not show this behaviour.
I don't know why this is happening and I was wondering if you could help me out figure this out.
Thank you in advance for your time and help!
System:
mac OS Big Sur
RME UCX, Firmware v46, driver v3.25
Total Mix, Digital Audio Workstation Mode
