1 (edited by razzkazz 2021-11-24 16:56:45)
Topic: Is everything MIDI controllable/mappable
I am think about getting a Fireface UCX II, and have some questions about MIDI control. I looked at the manual, and it doesn't look like you can do what I want, but I want to make sure.
The advertising says Totalmix is MIDI controllable. I would like to use a 16 knob MIDI controller and control Totalmix like a live mixer; control input level faders, control EQ fully, and effect sends.
Is this possible or are only certain parameters mappable?
Re: Is everything MIDI controllable/mappable
Download the manual from UCXII product page. There is a chart on p.84
I already looked at this, so to clarify, or maybe i'm reading it wrong wink This page relates mostly to Mackie control, I am interested in regular MIDI control. The available mapping options are the same?
So no full control over eq parameters or fx sends and parameters? And only the first 8 channel faders are controllable?
Full control is only available via OSC. MIDI can not control the EQ/FX.
Ok, Matthias. Thanks for clearing that up
@ razzkazz
with midi notes E1,F1,A#1,B1,C2 and C#2 you can move those 8 controls around.
https://forum.rme-audio.de/viewtopic.php?id=24437
