> However giving that it is all the way down, why I can still hear my bass?
> I would assume that when it is on the bottom I shouldn’t hear anything.
I think this refers to submix mode and routing.
Every HW output in the bottom row has an individual submix of its own.
Once you select one of the HW outputs in the bottom, then the fader position of
- HW inputs (top row)
- SW playbacks (middle row)
show you, what audio channels will be send to this particular hw output (aka submix, hence the name submix mode).
You should read about this in the manual and RME video tutorials and I also offer a blog artice about a good 1st time setup for RME recording interfaces...
For you and others I put some information together here:
https://forum.rme-audio.de/viewtopic.ph … 97#p180197
> Also regarding the -10dbv button question, Why my bass sounds better when pressing on it?
Your recording interfaces inputs and outputs work with different reference levels to optimize the operation of the AD/DA converters in terms of signal level.
On HW outputs different / lower reference level allow you to reduce the volume of an output signal without loosing SNR/dynamic. Reasons can be simply volume or if the connected device doesn't allow for high(er) signal / studio levels (-> overload, distortion, ...).
On HW inputs (your case) you have different reference levels to prevent overloading the input and to find the optimum reference level depending on the strenth of the input signal so that the converter can work at its sweet spot.
The lower the chosen reference level for your input is, the louder the signal, the higher the chosen reference level is, the more headroom you have for higher levels or peaks and the signal will become more silent.
In your case -10dBv is so called "consumer level", the typical (lower) level that consumer devices deliver.
And it might lead you to the sweet spot of sound, that the input signal is high, but not too high.
If you do not change the signal level on the connected device and you simply switch between consumer and professional reference level, then consumer level will be louder and by this (how our ears and brain works) automatically sound better (this refers to psychoacoustic and therefore the loudness war in the music industry, the louder the better, but sadly not the best quality).
BR Ramses
UFX+, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1650v4, Win10Pro21H2, Cub12Pro
