1 (edited by chriszichrisz 2022-01-08 21:57:23)
Topic: [Solved] HDSPe AES PCIe with 2 ADI-8 DS MK III => no signal
I have switched from my RayDat card to a HDSPe AES PCI Express Interface in order to record 16 channels at 192khz
My setup consists of the HDSPe AES connected via 2 Avid DB25 Digisnakes to 2 ADI-8 DS MK III's. I have WordClock coax cables (75 Ohm) connected from the HDSPe AES, which is master, a 75 Ohms Resistor is connected to the WordClock-In. The first ADI-8 DS receives the WordClock, and the second ADI-8 DS receives the WordClock from the 1st, this device has the blue "terminate" button active. The first ADI-8 DS is connected to the 1-8 AES, and the second ADI-8 DS is connected to the 9-16 AES. The Clock section of both ADI's is set to WCK. The DS/QS state is not changeable when I set 192khz in the card, this seems to be correct.
The problem: I don't hear anything coming out of the speakers, nor do I see anything coming into the card. D/A state is blinking and the "Input status" of the Hammerfall DSP Settings is "No Lock". I switched also to other sample rates, no success.
Here are screenshot of my Hammerfall DSP Settings
https://www.kjsd987327jf.com/temp/rme_aes1.PNG
https://www.kjsd987327jf.com/temp/rme_aes2.PNG
https://www.kjsd987327jf.com/temp/rme_aes3.PNG
My Raydat card worked like a charm it was intuitive, but here I really don't know what I am doing wrong. I must admit that I did not understand the WDM section, I don't know if the default factory settings are correct for my setup.
Any help would be appreciated.
Thanks,
Chris
Re: [Solved] HDSPe AES PCIe with 2 ADI-8 DS MK III => no signal
The ADI-8 has a lot buttons on the front panel, how does it look there ?
3
The whole Word stuff is unnecessary. Both ADIs can perfectly sync to the incoming AES signal if set up correctly.
The fact that zero signal is shown in the card's input status makes clear that your cables are not AES Tascam cables but something different. Or you plugged them into the analog DB25, instead of the digital one (the upper one).
Okay I used the wrong cables! I have the correct ones now and everything works fine now!
Also removed the wordclock, it is not necessary.
@MC => Thank you for your hint!
If anyone reads this who might have the same problem:  Please read about pin layout here, just ordering cables with "Tascam standard" is not enough (that was my mistake) => https://tascam.com/downloads/tascam/220 … Pinout.pdf
I am having a similar problem. I have a Yamaha mixing console with aes DB25 connectors.
Now I am trying to use an ALVA Yamaha to Tascam DB25 adapter, which I use together with a Digidesign Digital DB-25 cable which I use to connect the Tascam end of the adapter to the RME AES card.
However, I do not get any signal.  I am using a digidesign digital DB25 cable.
Thanks for any help.
The transfer from the rme-card to the mixing console is working in general (I checked with a yamaha DB25 to XLR cable on one side and connected those xlr with a further XLR to Tascam DB25 cable which connects to the rme card).
