1 (edited by babyface20 2022-01-16 18:20:17)
Topic: how can get at least 9 EQ for speaker or headphone corrections ?
Hello
I currently have no RME and i like to know if it is able to replace my speaker correction DSP with a babyface. I see that there are only 3 EQ possible in the Out channels and no EQ in the DAW output. thats too few. also it need possible to have EQ for left right channel with diffrent settings possible
maybe it is possible that can enhance the total mix and firmware so it can offer upto 10 EQ per channel ?.calc an EQ need not much calculation power. it can be dynamic too. i need no eq on all the input channels and no EQ for adat and spdif because i do not use them. so if they can be available for the out channels then it is enough for 10 EQ.
or maybe there is currently a way to work with more EQ ?  maybe can choose in DAW spdif with 3 EQ  do this loopback to input 1 2  and then have 3 EQ in  input 1 2 and 3 in DA output 1 2. is it possible that the channels work as single channel so can use seperate EQ for left and right ?
It is really usefull when can replace a correction dsp in a interface
2 (edited by ramses 2022-01-17 09:35:48)
Re: how can get at least 9 EQ for speaker or headphone corrections ?
You could use an Equalizer VST Plugins in a VST hosts application like "LiveProfessor".
TotalMix provides then the necessary routing between audio on your system and the VST host.
See this RME video:
https://www.youtube.com/watch?v=qQ95oc6zO3w&t=5s
A very good EQ is Fabfilter Pro Q 3: https://www.fabfilter.com/products/pro- … er-plug-in
babyface20 wrote:
Hello
Totalmix effects are functional but limited. If you need a computer-less solution, I believe UAD interfaces can host their own plugins on the hardware in standalone mode.
4 (edited by ramses 2022-01-17 11:30:52)
I find it a bit unfair to RME to propose a replacement on products from other manufacturers in their own forum.
Especially because stability is one of the core points of TotalMix FX and should not be endangered by 3rd party plugins.
Those who have such special requirements need to have special solutions like an external EQ or see above, which is what I suggested (flexibility, not bound to one manufacturer, more scalability and processing power with nowadays CPUs compared to the not so powerful Shark DSPs):
Then you stand with the purchase of a native plugin that can run on any Windows or Apple computer significantly better than with a UAD solution.
I personally could not consider UAD for the following reasons and therefore would not recommend it:
1. high purchase price, especially also with the UAD VSTs
2. VSTs can only be used on UAD interfaces with Shark DSP, so you are strongly bound to this platform.
3. partly very high DSP resource consumption with the VSTs.
4. quite limited DSP resources for the interfaces, especially for the smaller ones, above that it gets expensive very fast.
5. only the smaller interfaces with few Shark DSPs are available for Windows, but then only for Windows. The better interfaces with higher DSP performance are then also significantly more expensive and are only available for Apple. This is a rather inflexible design. What do I know if I won't switch to Apple because of Window 11. Thank you that I then also have to change my UAD.
6. instabilities under Windows 10 with e.g. UAD-2 Octo card
7. the used Shark DSPs are not very powerful and require quite fast the purchase of DSP resources in form of interfaces and/or accelerator cards
8. quite limited composition of different types of I/O ports, which do not allow flexible extensions via ADAT, MADI.
9. from what I have seen via Youtube I strongly doubt that you can achieve the usual flexibility of TM FX with the UAD Mixer and you will have to say goodbye to other very useful things like DIGIchech or even TotalMix Remote.
10. a bunch of spam in the mailbox. Lots of advertising and bait offers. Some of them are useful, but you can't ignore them completely, because you can't buy them at the regular price, it would be too expensive. Of course, if money is no object...
5 (edited by babyface20 2022-01-17 11:37:35)
See this RME video:
In this video they do not show roundtrip latency when they use live professor. I assume latency is double then. with 64 samples from 4 ms to 8 ms. no problem. but i need use 256 samples buffer. i have a fast CPU and windows over USB and a scarlet . 24 ms latency is acceptable but the double to 48 ms not.  when i use less buffer there happen sometimes random crackle because of large CPU spikes even if average XCPu load is only 6% also when not use much soft synths. i have a i5 8600K CPU and enough 32 GB ram and i notice no swapping. I have powersave disable and do all the tricks to get better realtime results.
when use a thunderbold pcie card in the PC. does this work always crackle free with a thunderbold device ?
6 (edited by vinark 2022-01-17 12:02:23)
I don´t think advising other brands is a problem here on the RME forum, but I agree in this case it is not really a good advice, as Ramses stated above, and I doubt the eq is very usable in standalone mode on the uad. BTW I still use and love my 2 uad-1 cards without issues.
I have not tried it, but maybe you can create multiple loopbacks on a babyface. Every loopback will give 3 bands so using the adats for loopback it would not be a problem. You could even obtain 15 bands like that at 44 or 48k.
edit, I had a look on my babyfave and I don`t think it is possible with the loopback function, but not sure, but it should be with an adat cable loopback.
4:01 ?!
I reread your original post better and what you want is possible. You can split stereo channels into left and right for different settings. If you use adat and not spdif for your loopback you can add 4 roundtrips if needed which will give you 24 bands lol.
Also expect low latency to be better with RME then focusrite drivers.
I would like to add the applying that much correction might not be to good an idea. Speakers should sound just fine as they are and flat and perfect is unobtainable and unnecessary. It is better to get used to the way your speakers sound. All IMHO of course.
9 (edited by babyface20 2022-01-17 14:23:40)
4:01 ?!
you can see on right side of total mix that there is no live professor run.n only at 15:48 he start live professor. then you can see that there are no inputs and outputs used from the RME . he only add this inputs later. but he do then no roundtrip latency check.
@vinark
it is for diffrent room correction. currently i have only a  mini dsp and this have 6 bands. and i miss 1 -2 bands often.  Have the speaker management inside save alot of cables and power supply that need connect. the dsp need another USB cable to control. the scarlet need power supply the dsp need powersupply and cable to connect interface to dsp.   the UAD is too expensive when want more in outs . the babyface is usb powered and can also work standalone. and if i want more in outs i can buy a cheap behringer AD18xx whoch have 8 io and adat.
if i can choose adat 1/2 in DAW route to adat 1/2 out then loopback the adat 1/2 out to out analog  1/2 look good. please can you tell when you route as this are the equalizers working from adat 1/2 out too also when loopback is choose . so i can use 9 EQ ?. . there need not all EQ for left right independent, because best is when can avoid diffrent eq for left and right side. but sometimes need it. so analog can stay as stereo.
10 (edited by Manuel 2022-01-17 15:01:19)
Not meaning to piss on anyone's turf but I think we've all browsed through competing brands' products before buying RME gear. RME interfaces sell like hot cakes because they are top quality and very competitively priced, and what I say here doesn't change that. The final choice is always down to features and price. Some times looking through competing products is what encourages to buy RME products, because I am reminded of the features I'll be missing on if I don't buy RME (e.g. Totalmix, Digicheck).
The OP appeared to require a standalone hardware EQ solution to perform some kind of crude room correction. A 3-band EQ is inadequate for that so I mentioned the next best thing that came to mind. That said, I need to make a correction there because I've just checked what actual EQ plugins they offer, and it seems their most flexible EQ plugin is a mere 5-band parametric EQ one that costs 299 USD (now that's value...). Objectively speaking, a 5-band EQ isn't adequate for room correction either (unless the starting room response was already very close to perfect), so my recommendation is not really valid.
The OP may want to try looping audio back through a decent EQ plugin or Sonarworks, as others have suggested, though that's not exactly standalone, or look into dedicated standalone room correction hardware (Dirac, etc) which probably much more.
Yes you can but then you cant use the adat for a behringer anymore. Still if you need that much and many eq why don`t you do it in the daw itself. For example it is easy in cubase control room and have as many presets as you need for the eq. For example freq is a cubase eq plugin with 8 bands that is very good.
12 (edited by babyface20 2022-01-17 16:43:58)
does the loopback switch switch all 8 adat channels then to loopback ?. when only use 4 channels for EQ (2 for speakers 2 for headphones), can i use the other 4 channels not with a adat able device ?
i hear with headphones or speakers. for headphones i use other correction.i have try in vst but often i forget to switch and after some minutes i think hmm that sound not good. ah forget to switch
automatic speaker correction sound not so good for me. I also develop or change my speakers. diffrent sound is nice when hear ready mixed music. the cpontrol in cubase is only on the expensive cubase version
realy sad that there can not use more EQ. the UAD mixer allow 4 slots and 1 precision Eq have 5 stereo bands.  so 20 EQ possible thats more than enough. but the solo is limit in input and output
13 (edited by waedi 2022-01-17 17:02:51)
No it does not switch all 8 adat channels.
The Loopback switch is for a stereo output channel.
It provides the signal to the input channel but it does not kill the output channel.
The signal is still going to the output, Loopback makes a copy of it on the input channel.
You should try Reaper DAW for your multi EQ thing.
The routing possibilities of Totalmix together with Reaper are endless.
14 (edited by vinark 2022-01-17 17:13:29)
As for as I understand it and tried it, you can not use the loopback switch for this. The loopback does not appear on the totalmix inputs, but only at the daw inputs. SO for this kind of loopback you will need a physical connection.
Still I think with more the 3 bands you do more harm then good. 3 bands ok, a little more or less bass. Rmove some mid bloom, add or remove some highs, maybe fine, but more might be a bad idea anyway. It is impossible to overcome limitations in your speakers or room with eq, except for some broad strokes or one or 2 resonances, but better to fix those.
the other practice room or when do gigs can only let sound ok with EQ. and 9 parametric eq give good results. if really not then can add the DSP and have additional 6 EQ. i use my equipment not only at home and not only my speakers
16 (edited by vinark 2022-01-17 18:26:33)
Ah ok now I get it,  I was already thinking I only ever needed that kind of eq in a live situation.
There is one other solution for the loopback I guess, you could do an analogue loopback of outputs 3/4 to inputs 3/4 and gain 2X 3eq's (and loose the headphones out). That way you adats are free. With this quality of converters that is no problem. Cause the babyface has snapshots you could also use both methods in different situations when needed.
I like your way of thinking in getting the most out of this device.
17 (edited by babyface20 2022-01-18 10:34:43)
with the roundtrip test i notice that my scarlet with 128 samples buffer at 48 khz have 12.6 ms and it add text suspect value. the value is correct, studio one show same. I also wonder before wy the real latency is 4* more as the buffer size. 2* more is mathematical correct.
In the rme video can see they use windows and they come to 8 ms with 128 samples and 48 khz. with 64 samples they reach 4 ms. I need buffer of 32 to reach 4 ms. but then it crackle soon when use kontakt
which value does the rtl roundtrip test from RME video show when use 256 samples and 48 khz  on babyface windows 10 64 and if possible a mac if there is diffrence ?.  there can download the https://oblique-audio.com/rtl-utility.php
is there somewhere a vst in which can choose a stay in plugin time in microseconds so can simulate CPU load ?
18 (edited by kathampy 2022-01-19 09:16:34)
There's no connection between the interface's buffer size and plugin latency. A plugin can process each sample in the stream in real-time with a latency of < 1 sample from input to output - the limit is the CPU performance, not the sample rate. A plugin will process an incoming sample as fast as possible, send it down the chain, then idle till the next sample arrives. The only time it necessarily takes longer than 1 sample is if you're running a convolution or function that requires multiple samples as input - now the limit is the sample rate. The latency is the number of samples required by the function and is not related to the interface's buffer size. The plugin typically operates on pre-existing input and output buffers. Each time the plugin is invoked, it's informed how many new samples are in the buffer. All of these new samples can be simultaneously processed in < 1 sample latency depending on CPU performance. It doesn't need its own IO buffers which would add latency.
Changing the frequency response with EQ requires phase shifts and necessarily adds output latency in the order of a few milliseconds.
Equalizer APO supports hosting VSTs. You can see the latency and CPU usage of all the stages you've added in Equalizer APO.
19 (edited by mr.r 2022-06-18 22:33:23)
A lot more EQ poles than 3 is also my 1# missing feature with RME. 6-10 with a good adjustable Q are perfect. I'm fine with having no FX as a ballance on other channels.
I know alll the loopback tricks, but it's not great to use.
