I find it a bit unfair to RME to propose a replacement on products from other manufacturers in their own forum.
Especially because stability is one of the core points of TotalMix FX and should not be endangered by 3rd party plugins.
Those who have such special requirements need to have special solutions like an external EQ or see above, which is what I suggested (flexibility, not bound to one manufacturer, more scalability and processing power with nowadays CPUs compared to the not so powerful Shark DSPs):
Then you stand with the purchase of a native plugin that can run on any Windows or Apple computer significantly better than with a UAD solution.
I personally could not consider UAD for the following reasons and therefore would not recommend it:
1. high purchase price, especially also with the UAD VSTs
2. VSTs can only be used on UAD interfaces with Shark DSP, so you are strongly bound to this platform.
3. partly very high DSP resource consumption with the VSTs.
4. quite limited DSP resources for the interfaces, especially for the smaller ones, above that it gets expensive very fast.
5. only the smaller interfaces with few Shark DSPs are available for Windows, but then only for Windows. The better interfaces with higher DSP performance are then also significantly more expensive and are only available for Apple. This is a rather inflexible design. What do I know if I won't switch to Apple because of Window 11. Thank you that I then also have to change my UAD.
6. instabilities under Windows 10 with e.g. UAD-2 Octo card
7. the used Shark DSPs are not very powerful and require quite fast the purchase of DSP resources in form of interfaces and/or accelerator cards
8. quite limited composition of different types of I/O ports, which do not allow flexible extensions via ADAT, MADI.
9. from what I have seen via Youtube I strongly doubt that you can achieve the usual flexibility of TM FX with the UAD Mixer and you will have to say goodbye to other very useful things like DIGIchech or even TotalMix Remote.
10. a bunch of spam in the mailbox. Lots of advertising and bait offers. Some of them are useful, but you can't ignore them completely, because you can't buy them at the regular price, it would be too expensive. Of course, if money is no object...
