Topic: Which adapter on PH as mono line output?
I want to use PH 3/4 of ADI-2 Pro as a mono line output.
I had received already warnings with overload/short detected.
The manual specifies in Section 21.4:
"In case the output should operate as line output, an adapter TRS plug to RCA phono plugs,
or TRS plug to TS plug is required".
The manual specifies in Section 34.24:
"How do I connect the device to my other devices that have only RCA?
By a simple adapter mono 6.35 mm to RCA (also called Phono and Cinch).
The adapters are plugged into the rear input and outputs - done."
The manual does not tell which adapters can be used for the front outputs PH1/2 and PH3/4.
Option 1: Stereo Jack to RCA adapter. This adapter will usually short tip and ring (T and R of TRS), therefore creating a short between left and right channel.
Option 2: Mono Jack to RCA adapter (as shown in Section 34.24 of the manual). This adapter will short ring and sleeve (R and S of TRS), therefore shorting the right channel to ground.
Maybe option 2 is a valid configuration when choosing the output PH3/4 mono on left channel only?
