1 (edited by samurabe 2022-01-24 00:38:57)
Topic: Ufx "- no sound from 7/8 outputs...
Hey there...i have a problem with this unit....again...
There is simply no sound going out from 7/8 outputs. If there is any secret setting i should know about? Yes-i did total reset in Total Mix.
In the software i see signal in and signal out but i dont hear anything?
& month ago unit back from service, but now warranty is finish...i dont want to hear that i need to service again...
Greets
Little update:
I decide to try with my old setting of 2 pairs of studio monitors. There is sound when i switch A/B monitors when i connect them to 7/8 outputs. But when i assign second monitors to NONE, than i can not figure out to get normal routing signal...Seems like the problem is in software level...
Any idea?
2 (edited by ramses 2022-01-24 06:11:54)
Re: Ufx "- no sound from 7/8 outputs...
So ... if the AN7/8 outputs work, then it will probably only be a routing problem.
What does the submix of AN7/8 look like?
- check: is submix mode active (top right blue area)
- select HW output AN 7/8 with mouse
- play audio
- at which SW playback channel does audio appear (TM FX: middle row) and are the faders set to 0dB or infinity?
Please post screenshot of it while audio is playing so you can see that too.
Otherwise, if you should still have your problems with TM FX and operation:
https://forum.rme-audio.de/viewtopic.php?id=34394
If you do not know how to post pictures on RME forum:
https://www.tonstudio-forum.de/blog/ind … rum-EN-DE/
