Topic: A minor complaint
I'm an HDSP(e) AIO user, is it normal behaviour that the computer has to be rebooted when reducing the Buffer Size?
If I don't reboot the card basically doesn't work, I get ticking, crackling or just horrible noises.
Other than the above, I'm a happy camper with this card.
Cheers,
Mauri.
Some of my 'stuff'. https://www.youtube.com/user/puutappi
Re: A minor complaint
Sorry, but without more details about your setup, this posting is meaningless.
Apple or Windows ? What device ? What applications ? Which are the steps to reproduce this?
I can only speak for windows here. When using a DAW, it is usually always possible to change the buffer size during playback of sound or while the project is opened.
But this is not the case for all other applications such as music players where the developers do not have the experience to interface with an ASIO driver in a proper way.
To put one example: the author of MusicBee was so kind to fix / support change of sample rates during playback.
But changing the buffersize is still not possible without audio/playback to become stuck. Needs always a restart of the application (but not the computer).
So after this little background .. what is the setup and the problem exactly? I am wondering that you say, that a reboot is required. This sounds very strange, so more details would be interesting.
No, not normal... But indeed more details are required. Can you test the card in another slot?
I tested card in another slot, the same result...
_______________________________________________
My system:
Win 11 Pro x64
Cubase 11 Pro x64
WaveLab Elements 11 x64
HDSPe AIO audio card
Core 11th Gen i9-11900KF
ROG STRIX Z590-A GAMING WIFI mobo
ASUS Radeon RX 580 Series graphics
Corsair Vengeance LPX 32GB (2x16GB) 3600MHz CL18 DDR4
Corsair RM1000x 1000W Power Supply Fully Modular 80 Plus Gold
Noctua NH-D15 CPU cooler
6 Internal SSDs
1 External SSD 2 external HDDs
This is what brings the problem on:
Start PC
Start Cubase with Buffer set 256 for example
Open any project
Lower the Buffer to any lower number
Sound is garbled followed immediately with ticking which slowly increases in volume
Change Buffer, with project active, back to the higher number works fine
Lower Buffer number, back to garbled, ticking sound
This the only way I've found to fix this:
Leave the lower number in DSP Settings
Restart PC
All's good, everything is working fine.
Disabled all 3rd Party plugs, makes no difference.
I don't know what else to tell you...
Thanks for the replies,
Mauri.
